  • M
    mike_i replied to the thread Ohm specs.
    "Looking for the ohm and k-ohm specs" specs for what? I'm struggling to understand your question.
  • WIMUSKY
    WIMUSKY replied to the thread 2026 NFL/CFB News and Nonsense.
    Idk, probably not? He's only starting his 2nd year on a 5yr contract, not that contracts can't be broken... Couple that with a new...
  • Bondo
    Bondo replied to the thread Lund tyee I/O transom removal.
    Ayuh,..... Way back when I replaced the transom wood in my '74 Starcraft 221 Islander, I cut off a strip of the transom cap, changed...
  • Scott06
    Scott06 replied to the thread Mercruiser 5.0 replacement.
    the new long block I bought in 2016 is just about x2 now. Hard part is if there is a decent machine shop you will be waiting for them...
  • Bondo
    Bondo reacted to MikeSchinlaub's post in the thread Lund tyee I/O transom removal with Like Like.
    Ok, I get it now. I think I've done one like that a long time ago. The problem withthe rivets is you would have to have them back in...
  • D
    Do you think KOC might be on the hot seat if the season does not go well? 4 seasons still no post season win?
  • C
    Chris1956 replied to the thread Mercruiser 5.0 replacement.
    Have you checked the exhaust manifolds for water leaks into the exhaust passages? Also check the manifold to riser joint for leaks past...
  • C
    Chris1956 replied to the thread May Day help.
    Check spark immediately after it dies.
  • WIMUSKY
    WIMUSKY reacted to Chris1956's post in the thread Fourwinns doors shut with Like Like.
    I ended up with a '98 SeaSwirl 2100 DC with a 150HP Johnny. Sorry, no picture
  • WIMUSKY
  • C
    Chris1956 replied to the thread Tachometer/Regulator Question.
    That looks to be the water cooled voltage regulator. I bought one from CDI or Sierra, and it rusted out in a couple of years use in...
  • C
    cleve replied to the thread Tachometer/Regulator Question.
    Got some time this morning to test battery. It was 11.77 at rest and 11.72 with engine running at high idle. Assume the rectifier is...
  • Lou C
    Lou C replied to the thread Mercruiser 5.0 replacement.
    I got a bargain on my 4.3 V6 remans….$275 each BUT that was back in 2017! I used compressed air, solvent, gun brushes and thread...
  • IslandExplorer
    IslandExplorer reacted to 66Holiday924's post in the thread 1978 Islander 22 I/O with Like Like.
    yeah, they cut the plexiglass a little small in one area. Overall, I don't really care for how it's all fitting together, but looking at...
  • Cup420
    2003 Yamaha 50hp 4stroke... Looking for the ohm and k-ohm specs. Struggling to find this information and need to test.
