  • FLATHEAD
    FLATHEAD replied to the thread 2026 NFL/CFB News and Nonsense.
    It’s a shame Justin Jefferson doesn’t have a better QB than Murray or McCarthey to work with. Guy is a force.
  • Lou C
    Lou C replied to the thread Mercruiser 5.0 replacement.
    I started using an endoscope camera to check them without taking it all apart, takes like 10 min. The Volvo style exhaust (what I have...
  • nola mike
    Yup, I also assumed carb initially and rebuilt it yet again. If you don't have one for your 'rude (and if it's a CDI type system)...
  • B
    bcj.jones reacted to boscoe99's post in the thread Very weird Yamaha issue with Like Like.
    Posted below is what Yamaha has to say. That is all I have ever heard from them about this problem. Again, they offer no theory of...
  • B
    boscoe99 replied to the thread Very weird Yamaha issue.
  • dingbat
    dingbat replied to the thread Building a fishing boat..
    See more and more guys using FLIR for running in low light conditions. Supported by a number of Ethernet compatible chartplotters and MFDs
  • Lou C
    I used a local place in Deer Park, Long Island called Machine World. Got them in a day...
  • bruceb58
    bruceb58 replied to the thread How to correct positive camber.
    Buy a new axle. Cheaper than replacing tires.
  • M
    MikeSchinlaub reacted to Bondo's post in the thread Lund tyee I/O transom removal with Like Like.
    Ayuh,..... Way back when I replaced the transom wood in my '74 Starcraft 221 Islander, I cut off a strip of the transom cap, changed...
  • B
    bcj.jones replied to the thread Very weird Yamaha issue.
    Funny thing, I mentioned doing something similar on a different circuit to my buddy but we never did it. I will definitely try that...
  • B
    bcj.jones reacted to 99yam40's post in the thread Very weird Yamaha issue with Like Like.
    I am thinking a bad connection also on the 12 volt circuit +or -
  • B
    I am thinking that I would disconnect the CDI connector and inspect the terminals, particularly those for the yellow wire. Maybe then...
  • dingbat
    dingbat replied to the thread Ohm specs.
    Ohm testing a coil isn't a reliable means to measure the performance of a coil. I've had more bad coils test good more time than I can...
  • Cup420
    Cup420 replied to the thread Ohm specs.
    Sorry... I need to check the coils
  • Cup420
    Cup420 reacted to mike_i's post in the thread Ohm specs with Like Like.
    "Looking for the ohm and k-ohm specs" specs for what? I'm struggling to understand your question.
