B
Built For Speed
replied to the thread
May Day help
Will do thank u
Wednesday at 12:21 PM
F
Ferenc Gemesi
reacted to
alldodge's post
in the thread
Mercury 200dfi 1997
with
Like
It works the same way, only issue is will 50:1 oil mix flow correctly thru the injectors. My guess is yes but it's not my motor Mix...
Wednesday at 12:10 PM
C
How to correct positive camber
Gee, can you put the straight edge on the spindle? I would expect it to be bent down, no? I suppose it could be a loose bearing and/or...
Wednesday at 12:06 PM
Lou C
Volvo Penta 5.7 TBI still being a pain
keep at it you'll get it eventually!
Wednesday at 11:41 AM
dingbat
reacted to
Cup420's post
in the thread
Ohm specs
with
Like
Tested...ive got good spark
Wednesday at 11:31 AM
Cup420
Ohm specs
Wednesday at 11:16 AM
Cup420
reacted to
dingbat's post
in the thread
Ohm specs
with
Like
Ohm testing a coil isn't a reliable means to measure the performance of a coil. I've had more bad coils test good more time than I can...
B
Berkley1
reacted to
Scott Danforth's post
in the thread
with
Like
have you done a compression test? all cylinders near 150 psi?
Wednesday at 11:13 AM
B
Berkley1
Yes pulled the tube completely clean
Wednesday at 11:12 AM
B
Berkley1
I do not Thanks though
nola mike
1997 5.7L thunderbolt ignition. Slow crank
Only thing I don't like about removing the lags is messing around with a penetration into wood. Mine are gooped in there pretty good...
Wednesday at 11:10 AM
B
bcj.jones
Very weird Yamaha issue
Good point! My brain always wants to know the "why" but there's a lot in life that just doesn't give us those answers. Does Yamaha have...
Wednesday at 11:02 AM
FLATHEAD
2026 NFL/CFB News and Nonsense
It’s a shame Justin Jefferson doesn’t have a better QB than Murray or McCarthey to work with. Guy is a force.
Wednesday at 11:00 AM
Lou C
Mercruiser 5.0 replacement
I started using an endoscope camera to check them without taking it all apart, takes like 10 min. The Volvo style exhaust (what I have...
Wednesday at 10:56 AM
nola mike
Engine misfires after rain storm
Yup, I also assumed carb initially and rebuilt it yet again. If you don't have one for your 'rude (and if it's a CDI type system)...
Wednesday at 10:55 AM
