S
svb165
replied to the thread
Mercruiser 5.0 replacement
IIn case you go the replacement route----m running a marine 5.7 from these guys in Tyler TX. for a great price. I did the same upgrade...
Wednesday at 2:58 PM
D
Dalejam
Need HELP identifying motor first
It’s in a barrel of water , what should the idle be in neutral
tpenfield
[SPLASHED] I/O (Sterndrive) Conversion to Outboards
Here is an interesting chart. I compared the speed vs RPM of the 'standard' CY338 Outboard (Bracket) with my boat CY338 with extension...
Wednesday at 2:57 PM
tpenfield
reacted to
Lou C's post
in the thread
with
Haha
Looks great, I'm still getting used to yellow "ground" wires lol.
Wednesday at 2:46 PM
S
svb165
06-5.7 mpi mag starts,, stalls, starts stalls. ran fine last fall
Once I was able to get it scanned,,,,,,,,,,,,,,,,,, today. they replaced the map sensor and cleared the old codes. 35 min in and...
Wednesday at 2:44 PM
B
brunolund
Lund tyee I/O transom removal
i was actually thinking of just cutting that top angle off. wonder if i could also weld it back on? i’d have to leave a small gap so i...
Wednesday at 2:41 PM
BWR1953
posted the thread
Boat landing lights
in
Dockside Chat
This is hysterical. And I read all of the comments! Some were very funny and still others were the usual macho BS. Still and all, I...
Wednesday at 2:37 PM
S
svb165
reacted to
alldodge's post
in the thread
with
Like
You need to get the motor scanned The FP can be hot wired and it not effect the ECM, just remove the FP relay and place a jumper...
Wednesday at 2:36 PM
Berdink
posted the thread
Linkage Slop
in
Johnson & Evinrude Outboards
1994 Johnson 90hp v4 Crossflow. . The throttle Linkage has about 1/4 to 3/8 play. See video. It might be hard to see it, but the plastic...
Wednesday at 2:19 PM
S
saltchuckmatt
Shift Lever Pin Installation on 1986 Johnson 150 Crossflow J150TXCDC
I also use the long screw driver.
Wednesday at 2:12 PM
S
saltchuckmatt
On muffs or barrel idle is set to low.
Wednesday at 2:09 PM
M
Mc Tool
reacted to
mike_i's post
in the thread
Ohm specs
with
Like
"Looking for the ohm and k-ohm specs" specs for what? I'm struggling to understand your question.
Wednesday at 2:06 PM
Dukedog
May Day help
pump tha "bulb" when it starts ta act stupid.. if that works then its bad.. next push tha key "in" (activates tha enrichner circuit) and...
Wednesday at 1:40 PM
metalchewy
reacted to
redneck joe's post
in the thread
Building a fishing boat.
with
Like
i was going out yesterday until the daughter called and told me she had a plumbing leak. today is new electric panel tomorrow? Heres...
Wednesday at 1:32 PM
190Marco
posted the thread
2003 Johnson 115 – Vacuum/Bypass Hose Diagram & Check Valve Elbow (P/N 0437784) Question
in
I bought a used 2003 Johnson 115 that never ran very well. I ended up replacing the powerhead with an OBR powerhead, and the engine now...
Wednesday at 1:23 PM
