K
KM7
replied to the thread
How Do I remove the Thermostat from the Housing, Ford 5.8
Thank you. I found a video on YouTube that shows the O-ring being removed with a sharp pick. I should be able to get it out.
Yesterday at 10:30 PM
G
Gbakman53
posted the thread
New product for boat repair
in
Boat Restoration, Building, and Hull Repair
I came across this product today and thought I might share it with others who might have a similar need for a waterproofing solution...
Yesterday at 10:18 PM
Berdink
reacted to
jimmbo's post
in the thread
Linkage Slop
with
Like
Cable may need replacing. In the 60s the Cable Ends could be tightened when they got loose. I don't know if the Silver Item, between the...
Yesterday at 9:53 PM
jimmbo
Linkage Slop
Yesterday at 9:32 PM
M
Mc Tool
Is this possible?
Oh I think a skinnier girl with less heavy clothes would be better 😆
Yesterday at 9:19 PM
66Holiday924
1978 Islander 22 I/O
I rough sanded, cleaned, and primed the cabin bulkheads. I used tractor paint on my other boat, and it worked out well, so I decided to...
Yesterday at 9:06 PM
K
Kissdude
1986 Mercury 9.8 110 outboard
compression numbers are around 98
Yesterday at 8:39 PM
N
Nextelbuddy
Engine is gas lighting me
Thank you! That is a great perspective and definitely puts me down a much better path for troubleshooting.
Yesterday at 8:36 PM
N
Nextelbuddy
reacted to
Fun Times's post
in the thread
with
Like
Theory/s... Looking at the design of your oil dipstick to oil pan configuration, one thought could be how was the condition of the old...
jimmbo
Air-Fuel, Compression, and Spark at the proper time and it should fire. You have fuel, in the cylinder What are the Compression...
Yesterday at 8:33 PM
K
Kissdude
If I have good spark on both cylinders a spray of premi9x into carb should fire correct? Cause I can't get this thing to fire at all
Yesterday at 8:17 PM
metalchewy
reacted to
Mc Tool's post
in the thread
Nobody fishing?
with
Like
Oh well if where baggin the Mrs mines real good at going along with some plan untill we are just past the point of no return and then...
Yesterday at 8:13 PM
jimmbo
It appears to be functioning, but once it warms up, it could become unstable.
Yesterday at 8:10 PM
jimmbo
Sputtering Johnson V4 90hp - 1994
Having the same Splines, doesn't mean it is going to fit properly.
Yesterday at 8:06 PM
metalchewy
Force 2 cylinder throttle cable adustments
Its a US Marine controller, out of the 1990 bayliner capri. I didn't seem to get pictures of it outside the box we built to mount it...
Yesterday at 8:05 PM
