T
todd57
reacted to
jimmbo's post
in the thread
1984 35hp Lower Unit Removal Trouble
with
Like
You just have to remove the Bolts/Nuts that hold the Gearcase to the Exhaust Housing, and it will come apart. Don't forget about the...
Aug 20, 2026
southkogs
reacted to
Scott Danforth's post
in the thread
Thinking of getting a sailboat . . .
with
Like
its like cooking an egg...... once you start, no undoing it.
Aug 20, 2026
P
Pmt133
replied to the thread
[SPLASHED] I/O (Sterndrive) Conversion to Outboards
I just tossed 700 in the 330 and it isn't even close to half a tank. :rolleyes:
Aug 20, 2026
D
DeepCMark58A
rant
Bone spurs on your vertebrae.
Aug 20, 2026
eggs712
1985 Bayliner 2750 Ciera Sunbridge Resto
Due to ease of install and costs, I went with a turn-key 350 Vortec SBC from Michigan Motorz that will bolt up to my 280 outdrive with...
Aug 20, 2026
R
1994 140hp v4. Hard starting and intermittent rough idling and dying.
Step #1 is a compression test.----Post actual values here.
Aug 20, 2026
3.0 mercruiser engine
I will second the what engine are you thinking swapping from a 3.0 to a 4.3 or 5.0 or 5.7 can be done. however needs to have a bunch...
Aug 20, 2026
M
Mrobi
posted the thread
in
Johnson & Evinrude Outboards
Will 1 poorly set idle screw cause hard starting and intermittent rough idleI and dying . And horrible build up on the cylinder 1 &3...
Aug 20, 2026
tpenfield
reacted to
in the thread
with
Like
Aug 20, 2026
Woods 9180RD Batwing came apart
Welding and Planting are two things where penetration is critical
Aug 20, 2026
Aug 20, 2026
Scott06
maybe a few more details on what boat and what you are looking to do? Most common swap is a 4.3 V6 if you are looking for more power...
Aug 20, 2026
tpenfield
95 Sea Ray 230 Sundancer stringer repair
BTW - 1708 cloth yields about 0.045” thickness. So, the 4 layers on the transom are getting you 0.190” thickness (y)
Aug 20, 2026
tpenfield
Yes. Kind of wish I hadn’t done that, but it will be easier to take the old foam out
Aug 20, 2026
tpenfield
reacted to
in the thread
with
Like
Did you ever get the 2-pieces of the hull separated?
Aug 20, 2026
