B
bakerjw
reacted to
tpenfield's post
in the thread
95 Sea Ray 230 Sundancer stringer repair
with
Like
It's not too late to make this project an outboard conversion. :unsure: :LOL:
Aug 20, 2026
J
-JR-
posted the thread
Best way to mount bunk boards
in
Trailers and Towing
Going to unload the boat at the lake so I can replace one rotten bunk board. Will have it wrapped and ready to install. But what's the...
Aug 20, 2026
flashback
reacted to
Scott Danforth's post
in the thread
Engine stalling when you give it too much throttle on take off
with
Like
have you check that the accelerator pump actually squirts when you advance the throttle?
Aug 20, 2026
O
ostrichegg
posted the thread
Mercruiser Cool Fuel Module (Gen III) cooling passages routing question
in
Mercury MerCruiser Sterndrives & Engines
I have a Gen III cool fuel module. It has a few caps that are bolted on, one over the filter and one over the pump. It also has water...
Aug 20, 2026
M
MikeSchinlaub
reacted to
bakerjw's post
in the thread
Stratos 1850 CC Rebuild Part 2
with
Like
It was 12 or 13 years ago that I took my Stratos 1850 down to a bare hull and built it back up. Money was much tighter back then so I...
Aug 20, 2026
Fun Times
reacted to
alldodge's post
in the thread
Woods 9180RD Batwing came apart
with
Sad
Pull the my Woods Batwing Turf mower in the fields behind my vacation rental. I keep an eye on maintenance checking gear box oil level...
Aug 20, 2026
B
bakerjw
posted the thread
in
Boat Restoration, Building, and Hull Repair
Aug 20, 2026
Ifishmuskie2
reacted to
in the thread
Piston soaking a 2 cycle outboard?
with
Like
With the puller putting tension on it. Add heat quickly, then a bit of percussive persuasion with a 5# maul
Aug 20, 2026
flashback
reacted to
Mc Tool's post
in the thread
Random
with
Like
Not like Im making a ally foil hat or anything but I think the world is in for a massive rearrangement weather wise ....flooding in what...
Aug 20, 2026
F
fishtilubleed
replied to the thread
Distance from lower gear case to prop
I cannot really tell if the splines are holding it back but the threads on the end of the shaft are about 3/16 to a 1/4 from pushing the...
Aug 20, 2026
Dukedog
200hp efi overheating
" his thought was that exhaust gas was getting into the water pump " this is almost impossible.. water pump is in a separated part of...
Aug 20, 2026
J
jlh3rd
that fuel hose is not grey, right?
Aug 20, 2026
tpenfield
reacted to
flashback's post
in the thread
Thinking of getting a sailboat . . .
with
Like
my last sailboat was an Oday 27. It's a good sailing boat ..wish i still had it..
Aug 20, 2026
skyman2112
thats a great idea, the fuel hose is new from the tank and its been removed and flushed didnt see anything. Runs great at wide open...
Aug 20, 2026
tg3690
reacted to
redneck joe's post
in the thread
Random
with
Like
https://www.facebook.com/share/r/1JFMYHu73q/
Aug 20, 2026
