Kwanza
posted the thread
Top unit noisy after bearing change
in
Volvo Penta I/O & Inboard Gas Engines & Outdrives
Migrating this from a different thread for better visibility. My Volvo Penta 3.0 GLP-D sterndrive (SX drive) cut off on water, restart...
Aug 20, 2026
S
saltchuckmatt
replied to the thread
1994 140hp v4. Hard starting and intermittent rough idling and dying.
Did we use all OEM parts?
Aug 20, 2026
jimmbo
Very Interesting Weather Pattern in these Clouds
Two Weather Fronts, meeting.
Aug 20, 2026
BWR1953
reacted to
Gbakman53's post
in the thread
with
Like
Several days ago I was able to take these pictures from my front porch. Very cool looking but very scary looking also. If you tap the...
Aug 20, 2026
A
airshot
Best way to mount bunk boards
I vote for the thru bolts as well. I also do not add carpet to the underside so water can come out of the wood and slow down decay...
Aug 20, 2026
G
Gbakman53
Boats from work.
I have to say that the boats that are being discussed are way too expensive for this old country guys. I am proud of my 1979 Fishmaster...
Aug 20, 2026
G
Gbakman53
posted the thread
in
Dockside Chat
Aug 20, 2026
Stinnett21
Alpha 1 Gen 2 shift question
Thanks for the reply Fun Times. I'll replace the cap/rotor. I've done it before, pretty easy job. Concerning the jumper wire, the SB...
Aug 20, 2026
G
Gbakman53
updated their
status
Been a while since I was on the internet and I have some catching up to do!
Aug 20, 2026
Fun Times
Your probably going to want to perform the test on page 3 of 3 jumping the shift switch, https://www.crowleymarine.com/sb/2/10455 If...
Aug 20, 2026
B
bakerjw
Rotted Plywood Edges
As advised. Replace it.
Aug 20, 2026
B
bakerjw
reacted to
DeepCMark58A's post
in the thread
with
Like
Buy exterior grade seal it install new, do not HA it. Once it starts getting soft it spreads.
Aug 20, 2026
Stinnett21
Engine: 2002 Merc 5.0 MPI, SN: 0M345638 Drive: 2002 Alpha 1 Gen 2, SN: 0M424120 I had a new shift cable installed this spring along...
Aug 20, 2026
M
MikeSchinlaub
Boats from work.
Finished the truck hood this morning. Then sprayed the basscat (forgot pics), cut some boards for stringers for a coworker, and...
Aug 20, 2026
B
bakerjw
Is it Safe to boat, knowing you have partial rotten stringer?
My Stratos had wet wood everywhere before I tackled the first rebuild. I had a couple of oopsies with it and went under the cap here...
Aug 20, 2026
