F
findinghomer
posted the thread
Question regarding wiring up a carter electric fuel pump
in
Boat Topics and Questions (not engine topics)
I am building my wiring harness for my new engine so I've been doing a lot of research and studying the proper way to do this here on...
Aug 21, 2026
1960 Starflite
reacted to
Stinnett21's post
in the thread
Alpha 1 Gen 2 shift question
with
Like
I'm trying to troubleshoot a shift issue with my alpha 1 gen 2. Question: Is it possible to have a remote shift cable (the one from...
Aug 21, 2026
C
replied to the thread
200hp efi overheating
Compression leaks causes overheating. Are you sure the head gasket you replaced is not leaking? Did you check the head and block for...
Aug 21, 2026
C
Distance from lower gear case to prop
Gee, I am not sure what engine you have. Sterndrive engineering (SEI) makes gearcases for popular motors, including Johnnyrudes.
Aug 21, 2026
W
workboot
I replaced the whole kit, and I do it every 3 years. As for the exhaust gas, doesn't it surround the water pump as it goes out through...
Aug 21, 2026
B
bakerjw
reacted to
gmach's post
in the thread
95 Sea Ray 230 Sundancer stringer repair
with
Like
Well it's been consistently in the 90's temperature wise here in California and so I have to work early in the morning or late in the...
Aug 21, 2026
M
MikeSchinlaub
reacted to
Gbakman53's post
in the thread
Boats from work.
with
Like
I have to say that the boats that are being discussed are way too expensive for this old country guys. I am proud of my 1979 Fishmaster...
Aug 21, 2026
Best way to mount bunk boards
countersink carriage bolts, then backfill the countersink area with caulk
Aug 21, 2026
T
tphoyt
reacted to
redneck joe's post
in the thread
Random
with
Like
Aug 21, 2026
Top unit noisy after bearing change
did the mechanic clean the oil strainer between the transmission and lower unit? did the mechanic pull the whole drive apart to clean...
Aug 21, 2026
P
Pmt133
reacted to
Gbakman53's post
in the thread
Boats from work.
with
Like
Aug 21, 2026
reacted to
jimmbo's post
in the thread
with
Like
Replacing those parts, isn't take the old one out/off, put the new one in. There are Shims in there to adjust the Gear Mesh, perhaps...
Aug 21, 2026
redneck joe
Random
Aug 21, 2026
redneck joe
reacted to
Gbakman53's post
in the thread
Boats from work.
with
Like
Aug 21, 2026
jimmbo
Aug 21, 2026
