M
Mrobi
replied to the thread
1994 140hp v4. Hard starting and intermittent rough idling and dying.
Will tackle next week. If I cant convince my wife that a new 60hp suzuki would make me love her more.
Aug 21, 2026
M
Mrobi
I have a digital multi meter
Aug 21, 2026
nola mike
Question regarding wiring up a carter electric fuel pump
The factory wiring doesn't use a relay. You're correct that the starter is back fed once the engine is running, but that connection...
Aug 21, 2026
flashback
Just thought I'd share a nice photo.
I think I found the little dipper, @Mc Tool it's your chance to see stars you don't see often. LOL.
Aug 21, 2026
flashback
reacted to
jlh3rd's post
in the thread
with
Like
that's just all goblety gook for say'n it takes a damn good pic, right?
Aug 21, 2026
C
Mercury 1996 60 hp running only on middle cylinder
Gee, if you have fuel, compression and spark, maybe the spark plug wires are arcing to ground, or you are getting water in the cylinders...
Aug 21, 2026
R
It is elegantly simple to work on these starters!----Nothing to them.----Just 2 bolts to take out.----Scratch the upper and lower parts...
Aug 21, 2026
legalfee
What is this cable? Should it be attached?
It's a Suzuki 2023 DF115A
Aug 21, 2026
M
Mrobi
Taking the starter apart doesn't sound simple. 50/50 on wether it ends up being free
Aug 21, 2026
M
mike_i
What motor?
Aug 21, 2026
R
That motor spinning over fast should start right up ! ---So load test the battery.----Take the starter apart for inspection as...
Aug 21, 2026
P
Pmt133
USPS, How does this even happen. Comical
I had a package depart from northern NJ to come to Central NJ... it ended up in Connecticut and took about a week to receive, bouncing...
Aug 21, 2026
M
Mrobi
Yes holding it in while cranking
Aug 21, 2026
M
Mrobi
Batteries are on charger. Starter cranks over motor fine. I normally just use the choke at 1st start. But then I'll fumble with it on...
Aug 21, 2026
T
tphoyt
Looks like a ground cable. You should find yhe other end under transom bricked. Probably a ring terminal.
Aug 21, 2026
