M
Mrobi
replied to the thread
1994 140hp v4. Hard starting and intermittent rough idling and dying.
Went from 2.5 out to 4 turns. Only got worse. Went back in to 2 with no improvement
Aug 21, 2026
legalfee
posted the thread
What is this cable? Should it be attached?
in
Boat Topics and Questions (not engine topics)
and should it be attached to sometyhing?
Aug 21, 2026
dingbat
Very Interesting Weather Pattern in these Clouds
Shelf cloud..... The last one that came over the house dropped an F1 tornado in the back field.
Aug 21, 2026
redneck joe
you have seen the movie haven't you???
Aug 21, 2026
R
Have battery charged and load tested.----Take starter apart for inspection and ohm test on armature.-----You are pushing the key in and...
Aug 21, 2026
redneck joe
reacted to
aspeck's post
in the thread
with
Like
That isn't a cloud ... you are being visited by a space ship from another galaxy!
Aug 21, 2026
M
Mrobi
Trying now. Got no 1 carb set screw working again.drilled a small hole trough the plastic into brass insert a little. Then threaded a...
Aug 21, 2026
dingbat
reacted to
BWR1953's post
in the thread
with
Like
Shelf cloud. Shelf clouds
Aug 21, 2026
A
Andrew Japatul
posted the thread
Mercury 1996 60 hp running only on middle cylinder
in
Mercury & Mariner Outboards
I believe Ive checked or replaced everything and sill no luck. It will run on the middle cylinder only with throttle advanced. Started...
Aug 21, 2026
aspeck
Aug 21, 2026
dingbat
USPS, How does this even happen. Comical
Had a similar thing happen a couple of months ago. Package went back and forth between Elkhart and South Bend IN twice.
Aug 21, 2026
F
findinghomer
reacted to
Scott Danforth's post
in the thread
Question regarding wiring up a carter electric fuel pump
with
Like
Thats how the circuit I use works. it also works as a starter interlock preventing cranking once the engine is running.
Aug 21, 2026
Aug 21, 2026
R
Distance from lower gear case to prop
Seadrives use an outboard gearcase.-----Hurry to boat repair shop and get the correct prop.
Aug 21, 2026
C
Crosbyman
setting idle screws back to recommend setting... tried openning up a bit ??
Aug 21, 2026
