What is this cable? Should it be attached?
tphoyt
Looks like a ground cable. You should find yhe other end under transom bricked. Probably a ring terminal.
boscoe99
Technically it is a bonding cable. A corrosion prevention device. Tries to keep components from having a difference of voltage.
It should be connected. In the photo the bonding wire appears to be missing the end terminal fitting.
mike_i
agree 100%
legalfee
Yes after some research I discovered it was a bonding wire. I suppose it should have black insulation over it like the other one that is connected. I can't find an O ring on a bolt it should be attached to. If someone could post a pic of one that is attached that would be great.
Fun Times
If you’re able to maybe locate an fuller? engine type serial or model number on your engine, it may help to find and confirm your exact engine parts catalog such as an example using 2023 115A which is probably close enough of a find preforming a online search helped shows Suzuki calling the bond cable a Lead as noted for item numbers 2,3,9 of the following parts guide's.
That appears covered in a sleeve.
