Yes after some research I discovered it was a bonding wire. I suppose it should have black insulation over it like the other one that is connected. I can't find an O ring on a bolt it should be attached to. If someone could post a pic of one that is attached that would be great.
If you’re able to maybe locate an fuller? engine type serial or model number on your engine, it may help to find and confirm your exact engine parts catalog such as an example using 2023 115A which is probably close enough of a find preforming a online search helped shows Suzuki calling the bond cable a Lead as noted for item numbers 2,3,9 of the following parts guide's.
