newtoboat101
replied to the thread
1988 THOMPSON 240 FISHERMAN REBUILD
hello so i have started getting materials together for transom rebuild and have sourced local coosa board ,now my question is...
Aug 24, 2026
newtoboat101
as i get into this project i can see that the aft end of the boat 1988 thompson 240 fisherman has been redone before shiffy job ,its all...
Aug 24, 2026
newtoboat101
Hello, my question right now is stringer replacement size, when i measure the existing wood stringer,some is exposed ,so i measure 3/4...
Aug 24, 2026
newtoboat101
posted the thread
in
Boat Restoration, Building, and Hull Repair
1988 thompson 240 fisherman fiberglass boat rebuild transom (see pics), my question is now that i have removed everything from the...
Aug 24, 2026
M
Mc Tool
1969 buick 225 oddfire
Cant you get an optical kit to replace points/condenser . I know that Crane used to have a one fits all . I have a 4 cyl one in my Capri
Aug 24, 2026
B
Boaterdan278michigan
320 Sea Ray
That is exactly right. It's just that everyone wants 10 to 30 percent over book. I don't think $75,000.00 to $80,000.00 for a 23 year...
Aug 24, 2026
There isn't a marine HEI distributor for the 225. However Davis Unified Ignition makes one for a jeep. You could contact them to see...
Aug 24, 2026
B
reacted to
redneck joe's post
in the thread
320 Sea Ray
with
Like
are you married to the 32 SR? Open up to other brands possibly size. Are you going to trailer?
Aug 24, 2026
Have an old OMC Stringer + engine... what to do with it?
Depends on what it is a d what the condition is. May be of value to someone trying to keep a stringer alive. May just be scrap
Aug 24, 2026
D
damo79
Mercruiser 4.5l low vacuum, WOT 4350 and higher fuel consumption
In post #149 you mentioned that maybe I have overloaded engine - wrong prop, gear ratio, engine misalignment. Is it anything else I can...
Aug 24, 2026
So, my 2025 Bayliner VR5 200 hp 4.5L mercruiser STILL barely pulls me up
You know that searay and bayliners under 25 feet are built in the same facility I would look at better brands than searay
Aug 24, 2026
I just bought a 2025 Bayliner VR5 with the 200hp 4.5L Mercruiser, - many issues - Low power, BARELY pulls me up slalom
Boats are the cheapest assembly of parts tossed together and slapped out the door, sold at a profit and the manufacturer hopes they...
Aug 24, 2026
reacted to
camboat's post
in the thread
Switching from Volvo TBI to Carb on a 1996 5.7 GI
with
Like
Today I went out crabbing for 3 hours. No oil burn from yesterday and today. I’m going to install a catch can system to each valve cover...
Aug 24, 2026
reacted to
Bt Doctur's post
in the thread
NLA shift interrupt micro switch
with
Like
additional research shows that the part number 87-81428A5 is listed as a normally open switch , this type applies a ground to the...
Aug 24, 2026
D
damo79
I checked what you asked for with Diacom recording. Checked graphs, looking at demand, rpm and trim. From what I can tell optimal max...
Aug 24, 2026
