replied to the thread
What is the Best Way to Repair the Snaps on a Sunbrella Cover
what ^ he said.
Aug 24, 2026
reacted to
Pmt133's post
in the thread
with
Like
I'd pull all the current snaps, stitch on a double of the fabric front and back and then install the new snaps in proper locations...
Aug 24, 2026
Stainless Steel Rowboat
look in the fiberglassics library
Aug 24, 2026
1969 buick 225 oddfire
DUI or Davis Unified Ignition makes HEI knock-offs sold under the DUI label. they also make marine units. they currently do not make a...
Aug 24, 2026
K
kirkj
2001 Mag MPI Alpha lugs
It has always run like this.
Aug 24, 2026
D
DeepCMark58A
Boy that nose pice and the corners sure look like old star craft hardware.
Aug 24, 2026
B
bigbadchevy89
Oh definitely the reason I was hoping just to find an hei! Is Marine distributor a website then or were you just being in general?
Aug 24, 2026
P
Pmt133
Aug 24, 2026
jimmbo
If the Springs are tired, the weights and pins are also likely worn, which all together affects the Rate of Advance as well as the Total...
Aug 24, 2026
T
Tapper54
posted the thread
in
Boat Topics and Questions (not engine topics)
Looking for information on a 14 ft stainless steel rowboat I picked up at auction about 35 years ago. I have since refinished gunwale...
Aug 24, 2026
S
saltchuckmatt
1989 3cyl 75 HP Evinrude - Running on One Cylinder? (Videos Included)
Just not water proof anymore.
Aug 24, 2026
Scott06
2010 VX1100 Oil Change
on my 2021 Sea Doo which also uses a dry sump - I use a vacuum extractor to suck out the pan, like you said you get a 3/4 of the oil out...
Aug 24, 2026
C
Crosbyman
Trying to identify 2000 Johnson/Suzuki 50 HP (J50PLSIB)
check yellows for AC volts from stator if ok .....bad rectifier or connection back to the battery B+ check all wires for corrosion...
Aug 24, 2026
M
MikeSchinlaub
reacted to
Watermann's post
in the thread
Random
with
Like
Aug 24, 2026
D
DeepCMark58A
reacted to
tphoyt's post
in the thread
rant
with
Like
Don’t blame you one bit. I always bring food and drinks when I’m invited somewhere and I’m all happy to help out. It’s just the right...
Aug 24, 2026
