J
Jmunk
posted the thread
Power Steering Pump - Angled Mount
in
Mercury MerCruiser Sterndrives & Engines
I have a 4.3MPI with serial number: 2A185156. I recently noticed when looking straight down onto the serpentine belt that the power...
Aug 24, 2026
M
MikeSchinlaub
reacted to
SlipperyOar's post
in the thread
1981 Springbok 18' Restoration/Renovation
with
Like
Waiting on my toggle bolts to finish the front two seats, got all of the wiring done to all the systems in the boat. Glued cable clips...
Aug 24, 2026
reacted to
muc's post
in the thread
2-4-C
with
Like
it's gone --- once available stock is sold engine coupler grease - gone u-joint and gimbal bearing grease - gone Special Lube 101 - gone...
Aug 24, 2026
O
OnThePontoon89
replied to the thread
1989 3cyl 75 HP Evinrude - Running on One Cylinder? (Videos Included)
I think the bullets are the lesser of two evils on a 45+ year old motor :). I put dialectric grease to help. If it became an issue Ill...
Aug 24, 2026
Berdink
Any clue what this gunk is?
I think I've gotten that gunk when I idled in a barrel too long. Is that what that motor calls for? Unless you have a vintage Johnson...
Aug 24, 2026
jimmbo
1969 buick 225 oddfire
The Vacuum Pot can be removed and the Breaker Plate for the points/sensor fixed in place, however the Jeep distributor would be illegal...
Aug 24, 2026
2-4-C
When I get a newer 8.2 with Gen 3 cool fuel I will be changing it over to older Gen 2 or even a Aeromotive (or other) with return to...
Aug 24, 2026
2-4-C
Stuff changes, things that don't bring in money is left behind Things that use to be use this or you will damage your drive/motor is...
Aug 24, 2026
C
Crosbyman
Trying to identify 2000 Johnson/Suzuki 50 HP (J50PLSIB)
check amazon #OB 12vdc volt /reg cheap just mount up somewhere
Aug 24, 2026
M
muc
posted the thread
2-4-C
in
Non-Repair Outboard Discussions
Aug 24, 2026
flashback
Stainless Steel Rowboat
I don't think anyone would be bold enough to say it's ss if it wasn't.
Aug 24, 2026
JimS123
Beautiful boat and excellent restoration. But are you sure it's not polished aluminum and not SS? If SS it must be pretty heavy.
Aug 24, 2026
B
bigbadchevy89
I wouldn't mind the points distributor off of the Jeep but won't that be a vacuum advance?
Aug 24, 2026
SlipperyOar
Aug 24, 2026
redneck joe
Retirement Financial Planing
we will be well below the $109k. They have a COLA on this number as well?
Aug 24, 2026
