S
saltchuckmatt
replied to the thread
1993 Johnson 9.9 lower cylinder wet.
Did you replace the impeller? A motor that's sits that long is bound to have cracked rubber. Swap coils, ohm everything out and if it...
Aug 24, 2026
S
saltchuckmatt
1989 3cyl 75 HP Evinrude - Running on One Cylinder? (Videos Included)
The ones you put on still need to be shrunk on both ends ...you missed a step. I have no problem with the bullet connectors. After...
Aug 24, 2026
S
saltchuckmatt
Any clue what this gunk is?
Confirms what the original milky flavor was.
Aug 24, 2026
nola mike
Question regarding wiring up a carter electric fuel pump
Yes/depends on the ignition
Aug 24, 2026
M
Mc Tool
Swap the plugs over and see if the fault follows .....might just be a duff plug 🤞
Aug 24, 2026
R
Robobrainiac
OMC 4.3 Electronic Ignition Swap
I was able to borrow an equus dwell meter from my dad. I installed new Sierra points and condenser, new standard motor products ignition...
Aug 24, 2026
J
Johnnyl30y
posted the thread
200 venom idle and runability
in
Johnson & Evinrude Outboards
I recently traded for a boat with a blown 1995 johnson 200hp venom motor. I did a powerhead swap and have struggled to get it running...
Aug 24, 2026
A
Abefish0
posted the thread
in
Hello, I recently bought a 1993 Johnson 9.9 2 stroke outboard. It was sitting for close to 20 years but the previous owner ran it out of...
Aug 24, 2026
B
bigbadchevy89
1969 buick 225 oddfire
I'll check this
Aug 24, 2026
R
The issue is perhaps the thermostat missing or stuck open.---Help yourself and post model # here !----I can not see / look over your motor.
Aug 24, 2026
K
kenny nunez
The 225 distributor was an automotive distributor with the vacuum advance location sealed and the plate stabilized as already mentioned...
Aug 24, 2026
T
Tapper54
Stainless Steel Rowboat
I too had questions......It is stainless according to an engineer friend who evaluated hardness, welds and other structural characteristics.
Aug 24, 2026
B
bigbadchevy89
Agreed but if I can get one for the right price and work through all my issues I wouldn't mind ordering the dui assembly. I spoke to...
Aug 24, 2026
M
Mc Tool
I dunno ,I have a friend ( yes I have some 😁) who is a sheetmetal worker , makes a few boat fuel tanks and I recall him saying about...
Aug 24, 2026
M
Mc Tool
Whats the diff ? Is the dizzy sealed against fuel vapour . And how hard / expensive would uscg compliancy be .... Just curious 🙂
Aug 24, 2026
