A
Abefish0
replied to the thread
1993 Johnson 9.9 lower cylinder wet.
Thanks, I did a spark gap test and both measured above 3/8’’. I also swapped top and bottom plugs and had no difference.
Aug 25, 2026
reacted to
Bondo's post
in the thread
2-4-C
with
Like
Ayuh,...... Well, that sucks,..... As for Perfect Seal, I believe permatex #3, the liquid, is exactly the same as perfect...
Aug 25, 2026
T
tphoyt
reacted to
Bondo's post
in the thread
2-4-C
with
Like
Aug 25, 2026
Scott06
Power Steering Pump - Angled Mount
Mine is the same way tends to Chaffe the outside edge of the belt but works fine otherwise. until your post I assumed I messed something...
Aug 25, 2026
reacted to
Stinnett21's post
in the thread
Best way to mount bunk boards
with
Like
I'm the original owner of a 2002 21' that I trailer and has many hours on it. I replaced my bunks once. They are attached with lag...
Aug 25, 2026
reacted to
Pmt133's post
in the thread
What is the Best Way to Repair the Snaps on a Sunbrella Cover
with
Like
I'd pull all the current snaps, stitch on a double of the fabric front and back and then install the new snaps in proper locations...
Aug 25, 2026
reacted to
rolmops's post
in the thread
with
Like
You can either get new snaps a few inches away from the original spots or have a strip sown onto the edge of the material and insert new...
Aug 25, 2026
2-4-C
Aug 25, 2026
T
tphoyt
reacted to
saltchuckmatt's post
in the thread
with
Like
Did you replace the impeller? A motor that's sits that long is bound to have cracked rubber. Swap coils, ohm everything out and if it...
Aug 25, 2026
2-4-C
I have been using a lot of farm implement greases lately. I use a lot of John Deere cornhead grease at work for worm gear actuators...
Aug 25, 2026
reacted to
alldodge's post
in the thread
2-4-C
with
Like
When I get a newer 8.2 with Gen 3 cool fuel I will be changing it over to older Gen 2 or even a Aeromotive (or other) with return to...
Aug 25, 2026
If your pulley is off and the belt isn't aligned, adjust the pulley installation until it's aligned The pulley installation or removal...
Aug 25, 2026
Stainless Steel Rowboat
They made Stainless StarCrafts.
Aug 25, 2026
bowler
Find an old singer 201k sewing machine. They cost pennies and are more than capable of sewing boat canvas.
Aug 25, 2026
Berdink
reacted to
racerone's post
in the thread
Any clue what this gunk is?
with
Like
The issue is perhaps the thermostat missing or stuck open.---Help yourself and post model # here !----I can not see / look over your motor.
Aug 24, 2026
