IslandExplorer
replied to the thread
Stainless Steel Rowboat
You won't be able to scratch stainless steel with a pocket knife very easily. Try in some obscure spot. Aluminum and magnesium (like on...
Aug 25, 2026
IslandExplorer
1974 Chieftain 25 "Adventurer" Restoration
Refinishing floors all week has been seriously wearing and slowing me down- but still made a little progress at least! More thru bolts...
Aug 25, 2026
T
Tapper54
Is there a high probability of mistaking magnesium for stainless steel or a straight forward way you know of differentiating the two...
Aug 25, 2026
reacted to
Bt Doctur's post
in the thread
2001 Mag MPI Alpha lugs
with
Like
are you absolutely sure you have a 350ci inch 5.7 motor? Almost sure the boat performed well before the cracked block and now it...
Aug 25, 2026
J
Jmunk
Power Steering Pump - Angled Mount
The mounting bracket is probably 3/16” or so steel so more then strong enough but it’s flat and the body of the pump isn’t. I see why...
Aug 25, 2026
R
1993 Johnson 9.9 lower cylinder wet.
Broken reed valve perhaps?
Aug 25, 2026
T
ttles714
remote motor control on-off-start
Boscoe 99 ... thanks buddy ... Based on what you told me ... here is what i am going to put together .. I am going to mount the...
Aug 25, 2026
S
saltchuckmatt
reacted to
tphoyt's post
in the thread
with
Like
You will need to take the pump apart to inspect the diaphragm. You would be looking for tears or even a very small pinhole. No fuel...
Aug 25, 2026
T
tphoyt
Aug 25, 2026
Bt Doctur
Aug 25, 2026
A
Abefish0
I appreciate the help. When I take the fuel pump off of the engine and squeeze the primer bulb, gas leaks out the sides but not the back...
Aug 25, 2026
redneck joe
Random
Aug 25, 2026
redneck joe
Random
i'm feeling that every day. Turns out that slight groin pain i've have for a couple weeks is a hernia. fun
Aug 25, 2026
R
200 venom idle and runability
Pushing the key in and holding it in while cranking for cold starting ?-----Does spark jump a gap of 3/8" on all leads?-----Water in fuel ?
Aug 25, 2026
R
Fuel pump diaphragm?----Easy to check and easy to fix if ruptured.
Aug 25, 2026
