F
findinghomer
replied to the thread
Question regarding wiring up a carter electric fuel pump
That's a great , thorough explanation, thank you! I totally get now , thanks to all you guys 🤘🏼
Aug 25, 2026
F
findinghomer
reacted to
JustJason's post
in the thread
with
Like
Technically it does, but only after the engine has started, not before the engine has started. But the power is on the bypass terminal...
Aug 25, 2026
G
garrettbirkhoff
Trying to identify 2000 Johnson/Suzuki 50 HP (J50PLSIB)
Got it! Thanks. The rectifier was faulty. Good voltage coming from the stator, but current flowing both ways across one of the diodes...
Aug 25, 2026
A
Abefish0
1993 Johnson 9.9 lower cylinder wet.
Thanks for all of the suggestions, before I take apart the fuel pump. Wouldn’t the needle/seat and float regulate to total amount of...
Aug 25, 2026
redneck joe
daily music fix
for those that do not know of Star Trek, this is in no way shape or form disrespectful.
Aug 25, 2026
JustJason
Aug 25, 2026
T
Tapper54
Stainless Steel Rowboat
Thanks all. I have to go now. It doesn't scratch easy, it rings and it says ss, so I guess I'll go with that for now.
Aug 25, 2026
K
kalebsheridan
Deep pitting inside water jacket on power head.
Okay cool, definitely going to do that. Do I need to get down to bare metal or is patina okay?
Aug 25, 2026
K
kalebsheridan
Interesting, Ive been looking in the parts diagram for this model and don't see any, only on the lower unit.
Aug 25, 2026
Mariner 40E 6E9 S 103761 Can't find a definitive year or manual
Doesn't take much of any amount of fuel to run high RPM in neutral You most likely have a fuel delivery issue What are tbe...
Aug 25, 2026
tpenfield
reacted to
alldodge's post
in the thread
320 Sea Ray
with
Like
102 is the Fed standard same is 13'6" on height. Many states have no issue with 9'6" and others is 10'0", but others have issue. That's...
Aug 25, 2026
C
CharleyMarbles
posted the thread
in
Mercury & Mariner Outboards
Trying to figure out why it dies under load. I've cleaned and rebuilt the carbs new fuel line checked compression it's good. good spark...
Aug 25, 2026
B
B-D215
reacted to
alldodge's post
in the thread
2006 D215 Sanger Mid-Engine Slow Leak
with
Like
As others have mentioned its most likely the prop shaft seal. Look online for a bore scope type camera that connects to your phone. You...
Aug 25, 2026
flashback
reacted to
FLATHEAD's post
in the thread
Just thought I'd share a nice photo.
with
Like
Watching the sunrise while out on the water is sweet.
Aug 25, 2026
redneck joe
my fathers musings
My Second Day On The Wanapum Team The next morning I was assigned to a different crew. It was, counting me, a three-man crew. The...
Aug 25, 2026
