C
Crosbyman
replied to the thread
Successful Deletion of VST, Primer, & Fuel Pump
ok not a FICHT .. carbed engine post mdl # !!
Aug 27, 2026
D
DeepCMark58A
rant
Get a scanner go paperless.
Aug 27, 2026
C
Crosbyman
how does the oil fuel mix bathed the crankcase if direct injected for combustion
Aug 27, 2026
L
Longarch
Fuel-oil is premixed in tank.
Aug 27, 2026
C
Crosbyman
Does the FICHT system provive for oiling of innards I am thinking ETEC with separate oiling no need for fuel oil mix in ETECs
Aug 27, 2026
K
Kosmofreeze
posted the thread
Sand Ingestion - DP-SM
in
Volvo Penta I/O & Inboard Gas Engines & Outdrives
Attempted to beach the boat the other day. Suffice it to say that it didn't work as planned and I sucked up a lot of sand in the...
Aug 27, 2026
Texasmark
cupped prop question
I guess I missed something over the years. Other than Turning Point Hustler aluminum prop mfgr. the only cupped props of which I was...
Aug 27, 2026
redneck joe
rant
i hate HP printers and HP in general
Aug 27, 2026
L
Longarch
posted the thread
in
Johnson & Evinrude Outboards
To avoid the high cost and desperate searching for used parts, I've successfully replaced the Vapor Separator Tank (VST), Choke /...
Aug 27, 2026
Texasmark
.....and the peak of the torque curve is usually much lower than the max RPM point.....at least that's the way it is on 4 stroke diesels...
Aug 27, 2026
Texasmark
reacted to
alldodge's post
in the thread
with
Like
There is always a give take between max RPM achievable and max RPM performance increase. Gaining that last 200 RPM may not gain any...
Aug 27, 2026
9
99yam40
Sand getting into Suzuki 20hp outboard - can I pull it out?
you can also try blowing compressed air up the tell tail outlet, while running on muffs or in a tub to see if that changed the spray...
Aug 27, 2026
tpenfield
White gelcoat restoration
There is a product called Re-Gel, which I believe is a 2-part product that cures like gelcoat. Basically a clear coat. There are some...
Aug 27, 2026
FLATHEAD
reacted to
Chris1956's post
in the thread
Deep pitting inside water jacket on power head.
with
Like
You can epoxy the pitted areas. If you clean the metal, wipe it with acetone and use Marine-Tex to fill the pits, it will add some time...
Aug 27, 2026
J
jlh3rd
it's in the range but I want to be at the max by myself.
Aug 27, 2026
