S
SteveD78
reacted to
Scott Danforth's post
in the thread
1997 Bayliner Capri Stringer and Floor Repair
with
Like
I would try to pull the cap. the cap will have screws and adhesive holding down most of it.
Aug 27, 2026
S
SteveD78
reacted to
bakerjw's post
in the thread
with
Like
Steve, just be aware that you are not alone. Many of us here have cracked open a can of worms just like you did and have lived to tell...
Aug 27, 2026
S
SteveD78
replied to the thread
Ya, that's crazy. That's exactly how it looks. Friday shift, ran out of material and said screw it, I wouldn't buy a Bayliner anyway 🤦...
Aug 27, 2026
flashback
rant
I like hp
Aug 27, 2026
redneck joe
rant
gotta print sometimes...
Aug 27, 2026
redneck joe
rant
you flying into Savannah or doing GA to Jekyll?
Aug 27, 2026
redneck joe
welcome to the forum. If you undertake it, plan for a big job ahead of you but as stated you will know you have a well built boat that...
Aug 27, 2026
2-4-C
And with everyone LS swapping good SBCs and BBCs, many good motors are in the $1k-2k range only needing a cam swap and marine electrics...
Aug 27, 2026
2-4-C
Ayuh,...... 'n Expensive,..... A 350 long block is $5,000,00 on a pallet, out the door,.... Used is less,.... An Alpha drive is...
Aug 27, 2026
B
biederboat
Sand getting into Suzuki 20hp outboard - can I pull it out?
Oh thanks all...I'll hopefully get it fixed up.
Aug 27, 2026
reacted to
in the thread
2-4-C
with
Like
Many dealers are struggling right now until you get into the range of boats that are resistant to financial climate changes. even great...
Aug 27, 2026
Sand Ingestion - DP-SM
Ayuh,...... When you change the impeller, flush from there, backwards out to the drive,.... When you drain the block, pull the plugs...
Aug 27, 2026
D
DeepCMark58A
rant
I have to go into the office tomorrow, on a Friday and stay till 5 pm traffic is going to suck. I also have a noon flight on Labor Day...
Aug 27, 2026
L
Longarch
Successful Deletion of VST, Primer, & Fuel Pump
The intake injection is the choke / primer. Yes, this is a 1998 carbruetor outboard.
Aug 27, 2026
reacted to
Texasmark's post
in the thread
cupped prop question
with
Like
.....and the peak of the torque curve is usually much lower than the max RPM point.....at least that's the way it is on 4 stroke diesels...
Aug 27, 2026
