C
replied to the thread
Successful Deletion of VST, Primer, & Fuel Pump
Gee, the VST solves the vapor lock issue and bubbles issue. In addition, the VST is simply a tank with a fuel inlet needle, just like a...
Aug 27, 2026
L
Longarch
1) Corectiin - Fuel manifold (X2) supplying two carbs rack. 2) Return keep fuel cool and reduces chance of 'vapor lock' Fuel return...
Aug 27, 2026
reacted to
Pmt133's post
in the thread
2-4-C
with
Like
My machine shop is still 2k for a complete short block and rebuild to whatever specs you want. 2400 for a long block. I can blow up a...
Aug 27, 2026
Sand Ingestion - DP-SM
do you have a heat exchanger, or are you raw water cooled. 1 of 3 things happen when you bury a VP drive in the sand. its light sand...
Aug 27, 2026
C
First of all, you do not have a fuel rail. Those supply fuel to injectors, not carbs. Secondarily, there is no reason to return fuel...
Aug 27, 2026
rant
IT bought us HP printers for the office. POS is being kind to them suckholes of life. T office is 1500 miles away and they wont set...
Aug 27, 2026
reacted to
redneck joe's post
in the thread
rant
with
Like
i hate HP printers and HP in general
Aug 27, 2026
C
cupped prop question
Gee, it is pretty easy to tell if a prop is cupped. Put a straight edge in the prop blade. If it sits flat on the whole blade, there...
Aug 27, 2026
redneck joe
1997 Bayliner Capri Stringer and Floor Repair
thats how it happens - a tarp/cover that collects water and falls in but hey its covered...
Aug 27, 2026
redneck joe
rant
i got a very lightly used printer i'll sell you...
Aug 27, 2026
P
Pmt133
2-4-C
Aug 27, 2026
S
SteveD78
Ya, slowly moving backwards from the Bow. Just working on the starboard side for now, that seemed like the worst side. Think someone...
Aug 27, 2026
S
SteveD78
reacted to
MikeSchinlaub's post
in the thread
with
Like
I can't see anything that looks like hull damage, but you're definitely in for a complete tear down. With the stringers that you can see...
Aug 27, 2026
S
SteveD78
reacted to
in the thread
with
Like
That would be my guess too. I've seen some stuff like that where it wasn't rolled out well, but not just skipped over. Unless there was...
Aug 27, 2026
S
SteveD78
reacted to
redneck joe's post
in the thread
with
Like
welcome to the forum. If you undertake it, plan for a big job ahead of you but as stated you will know you have a well built boat that...
Aug 27, 2026
