flashback
replied to the thread
rant
I use a printer once a year if that so I suspect any ink jet would dry up.
Aug 27, 2026
9
99yam40
Just cant figure this out...
either put a shut off valve in fuel line, turn it off, and then drain the carb bowls so no fuel sits in there and evaporates leaving...
Aug 27, 2026
jimmbo
cupped prop question
A lot of Props have Progressive Pitch Blades, and the Trailing Edge, will have the greatest Pitch
Aug 27, 2026
C
Ethanol, despite what the old wives tales say, is not bad for your fuel system. It will clean the fuel system upon first use, and that...
Aug 27, 2026
S
sailorboi
posted the thread
Timing marks on fly wheel.
in
Force & Chrysler Outboards
Hey y'all, I recently bought a 1979 starcraft with a 1974 55hp 557HG Chrysler outboard (Alternator version). The previous owner messed...
Aug 27, 2026
C
Crosbyman
Successful Deletion of VST, Primer, & Fuel Pump
properly fused hopefully with spares in the boat
Aug 27, 2026
roscoe
reacted to
redneck joe's post
in the thread
rant
with
Like
i hate HP printers and HP in general
Aug 27, 2026
Cup420
I finally figured out the problem, and it was my carbs. I just rebuilt them last year, but they were dirty, jets were clogged as well...
Aug 27, 2026
C
I never heard of VST warpage. The carb bowls do warp and need to be replaced. If you power the electric fuel pump from the starter...
Aug 27, 2026
Cup420
reacted to
airshot's post
in the thread
with
Like
I have never gotten more than mabey 5 years from cheap fuel hose, then I started buying the good stuff. Can't say I have owned a boat...
Aug 27, 2026
L
Longarch
Yes sir. I had VST warpage issues. A new gasket is very cheap but did not fix my issue.
Aug 27, 2026
S
saltchuckmatt
It's got a "roll over" switch. If your upside down, your safe! Definitely an issue. Boat fires are a major bummer.
Aug 27, 2026
L
Longarch
Sorry, Chris1956. I was using a cell phone and failed to see question / concern #4. I plan on using a tach safety sensor to shut the...
Aug 27, 2026
S
saltchuckmatt
reacted to
OnThePontoon89's post
in the thread
1989 3cyl 75 HP Evinrude - Running on One Cylinder? (Videos Included)
with
Like
Ya I already did. Pic was before heat shrinking. Heat shrunk the ends and wrapped in electrical tape. Given electrical issues I...
Aug 27, 2026
B
bakerjw
reacted to
redneck joe's post
in the thread
1997 Bayliner Capri Stringer and Floor Repair
with
Like
welcome to the forum. If you undertake it, plan for a big job ahead of you but as stated you will know you have a well built boat that...
Aug 27, 2026
