replied to the thread
cupped prop question
(making number up) So if you have 9 people on the toon and it's getting 2.5 MPG at 5500 rpm that is not relevant because you want to...
Aug 27, 2026
B
bakerjw
Repair of door latch
Can you get access behind it? Do you have some resin on hand and glass? I'd fabricate a backer plate and see if I could fish it in...
Aug 27, 2026
Then pitch down 2", and control the throttle with your right hand. You will be a tad high lightly loaded and not lugging it moving 9 people
Aug 27, 2026
J
jlh3rd
not speed or efficiency.... if I put 9 people on my pontoon I like seeing my motor running at the higher rpm.
Aug 27, 2026
Boats from work.
Don't look in the bilge....deny deny deny
Aug 27, 2026
posted the thread
in
Boat Restoration, Building, and Hull Repair
Suggestions on how to repair the latch hole? Yes this is my Craparral where looks like they used a drill bit to cut the hole instead of...
Aug 27, 2026
M
Mc Tool
Just cant figure this out...
I just disconnect the fuel hose at the motor and either run it out of fuel or drain the carbs ....🙄usually both 😁
Aug 27, 2026
M
MikeSchinlaub
Boats from work.
Ground everything in prep for the floor, made and glassed in a center stringer for extra support. Apparently, the owner and his brother...
Aug 27, 2026
redneck joe
rant
My canon would do that, eventually ruined the print head. I got the epson eco tank. I plan on printing a bit more in retirement...
Aug 27, 2026
redneck joe
non alcoholic beer
found the Athletic, all three. . Just finishing the Hazy IPA. Good, got over IPA a few years back but had to try
Aug 27, 2026
Berdink
Successful Deletion of VST, Primer, & Fuel Pump
I think I posted in your dupe thread. Does the electric fuel pump shut off when the engine dies?
Aug 27, 2026
Berdink
reacted to
racerone's post
in the thread
1990 E70TLESB Evinrude primer solenoid hoses
with
Like
These are not vacuum lines !!!!!!!-----The bigger hose supplies fuel to the solenoid valve.---When there is pressure on the fuel system...
Aug 27, 2026
reacted to
Pmt133's post
in the thread
2-4-C
with
Like
My machine shop is still 2k for a complete short block and rebuild to whatever specs you want. 2400 for a long block. I can blow up a...
Aug 27, 2026
dingbat
reacted to
Chris1956's post
in the thread
with
Like
Ethanol, despite what the old wives tales say, is not bad for your fuel system. It will clean the fuel system upon first use, and that...
Aug 27, 2026
C
Gee, I don't do any of that. I leave the fuel line connected to the engine all winter. It is a V6 with 6 carbs, so it would be hard...
Aug 27, 2026
