replied to the thread
Repair of door latch
hit the autobody supply store near you. get a pint or quart of tiger hair filler. then fill the voids and give the screw something to...
Aug 28, 2026
FLATHEAD
non alcoholic beer
Pa has a two tier liquor license requirement. A bar can get a limited license for only hundreds of dollars that allows them to serve...
Aug 28, 2026
dingbat
non alcoholic beer
Didn’t know that. So you can’t pump your own gas or eat at a bar in NJ…lol
Aug 28, 2026
D
DeepCMark58A
rant
Jacksonville direct flight to MSP
Aug 28, 2026
Big Gee
1962 Evinrude 40hp Lower Unit Leak?
https://www.westmarine.com/west-marine-premium-type-c-lower-unit-gear-lube-quart-17997628.html?utm_medium=cpc&utm_source=google&utm_campa...
Aug 28, 2026
Texasmark
cupped prop question
Yes. More bite = more load on the engine = drop in "work function" for a given fuel input.
Aug 28, 2026
B
bakerjw
Stratos 1850 CC Rebuild Part 2
Installing the transom. As I mentioned, When I originally reworked the transom, I had some thin air gaps between it and the outer skin...
Aug 28, 2026
Scott06
non alcoholic beer
Most of the issue with a lot of import beers in the US is the age of the beer - you are tasting staling flavors and oxidation. The shelf...
Aug 28, 2026
P
Pmt133
non alcoholic beer
I always forget it is only NJ that prohibits breweries from serving food at the same location and that it's actually not normal.
Aug 28, 2026
dingbat
non alcoholic beer
SIL started brewing in a garage as well. Has since converted a warehouse into a brewery with food and entertainment. Brews and cans ten...
Aug 28, 2026
Watermann
Another Maine Starchief
That's a shame, bet the chief finds itself in a new home in a field for probably a couple decades until who knows what.
Aug 28, 2026
Watermann
reacted to
Pmt133's post
in the thread
Just thought I'd share a nice photo.
with
Like
This is dad. This is the second time dad has driven the boat since the restoration. This is the first time dad has driven it at the lake...
Aug 28, 2026
Watermann
reacted to
Pmt133's post
in the thread
with
Like
First time in a long time I've beached it. Got some lunch.
Aug 28, 2026
B
bakerjw
Time to LAMINATE!!! Using the alignment holes. I inserted 1/2" rubber tubing as I did the lamination. I used epoxy and 1708 glass...
Aug 28, 2026
B
bakerjw
New transom time Using 2 sheets of 3/4" Coosa 30. Template made and marked. Ready to cut. Checking fitment. As the original transom...
Aug 28, 2026
