J
Jeff J
replied to the thread
Burning valves and melting spark plugs 5.7 efi
I agree with your thoughts about it going lean at high rpm. The kink in the fuel line could easily cause it. I don’t think a water...
Aug 30, 2026
R
Rebuilding carbs
Run fuel out of carburetors when motor sits for a week or more.----There is no need to " rebuild " a carburetor every season.----What...
Aug 30, 2026
dingbat
Ethanol!
Don’t trust that list. Says the station next to my office has E0. I know for a fact it does not.
Aug 30, 2026
tpenfield
Mercruiser 4.5l low vacuum, WOT 4350 and higher fuel consumption
Reving an engine under no load conditions does not prove anything, except maybe where your rev-limiter is at. 10˚ past TDC for leak...
Aug 30, 2026
dingbat
Ohm specs
There is no magic bullet….it wasn’t the fuel that caused the problem, it was/is your dirty /neglected fuel system. E10 is a great fuel...
Aug 30, 2026
C
Cdn20valve
posted the thread
in
Mercury MerCruiser Sterndrives & Engines
1996 5.7 efi 0F831652 TBI Hey guys. I'm having a problem with my port engine. for two years now I've been trying to fix this. I've...
Aug 30, 2026
P
Pmt133
Ethanol!
I'd hate to see what 100 octane costs on the water... 4 total stations in my state, not even worth the hassle.
Aug 30, 2026
Ethanol!
Ayuh,.... I drive a diesel pickup, 'n the only gas I buy is for my 1963 Jeep, or my various small motors, chainsaws, etc, which are...
Aug 30, 2026
dingbat
Ethanol!
I’ve had zero issues with the machines (2 and 4 stroke) since I started stabilizing all fuels and mixes at purchase that are not...
Aug 30, 2026
Texasmark
cupped prop question
Yea Jimmbo we both know that if its cupped, besides the progressive pitch, you can just look at the blade and clearly see the tip of the...
Aug 30, 2026
Cup420
Ohm specs
I figured out the problem...its the carbs. Just waiting on o-rings to rebuild. Most of my jets were clogged, but i'm still trying to...
Aug 30, 2026
Cup420
reacted to
boscoe99's post
in the thread
Ohm specs
with
Like
What is the motor doing or not doing?
Aug 30, 2026
P
Pmt133
Questions about the set up of a Holley 4160 on a 4.3 V6
Do you even really need it? The choke didn't work on my 3.0l for like 15 years.
Aug 30, 2026
R
reacted to
Chris1956's post
in the thread
80 HP Mercury trim
with
Like
Do you have the PTT with the trim pump and reservoir in the boat? If so, you can have one or two solenoids. The UP circuit will...
Aug 30, 2026
Ethanol!
Might be closer than you think https://www.pure-gas.org/
Aug 30, 2026
