Cup420
reacted to
airshot's post
in the thread
Rebuilding carbs
with
Like
Or silicone grease, but just a tiny amount to make the O ring slippery so it can get seated properly.
Aug 30, 2026
Cup420
reacted to
airshot's post
in the thread
Rebuilding carbs
with
Like
Your probably buying contaminated fuel from your fuel supplier. No way should you have that much crud in your fuel system. Find...
Aug 30, 2026
A
airshot
replied to the thread
Rebuilding carbs
Aug 30, 2026
nola mike
reacted to
Jeff J's post
in the thread
Retirement Financial Planing
with
Like
My truck is a 2008. Wife’s car is a 2014. No plans for swapping them out. I paid off the truck in 2010 but kept sending the payment to a...
Aug 30, 2026
A
airshot
Rebuilding carbs
Aug 30, 2026
Lou C
Questions about the set up of a Holley 4160 on a 4.3 V6
The coldest we might get for early/late season is about 45*. I’d actually prefer a manual choke! The guys at ARCO told me to use a relay...
Aug 30, 2026
A
airshot
reacted to
Jeff J's post
in the thread
Rebuilding carbs
with
Like
I use petrolatum or the fluid the o-ring will be exposed (gasoline isn’t a good lube) to on nearly every o-ring I install. Oil and gas...
Aug 30, 2026
A
airshot
reacted to
racerone's post
in the thread
Rebuilding carbs
with
Like
Run fuel out of carburetors when motor sits for a week or more.----There is no need to " rebuild " a carburetor every season.----What...
Aug 30, 2026
A
airshot
Boat purchase
Starts and runs very well, idles good but a little high at 800 rpm. Bow high should be a trim issue that can be corrected unless there...
Aug 30, 2026
2
2009 stingray
V/P osxi-G 5.7 lack or power and 1 beep every 5-7 seconds
update: took the boat out with the intentions of verifying the false alert then replacing the riser sensors on the fly, verifying...
Aug 30, 2026
B
Boaterdan278michigan
Boat purchase
They cruised nicely at 3500rpm 25-27 mph. WOT appeared to be 4200-4500 rpm 40-42 mph with four people on board.
Aug 30, 2026
B
reacted to
tpenfield's post
in the thread
Boat purchase
with
Like
If the boat/engines reach their specifies RPM at full throttle and the boat speed seems reasonable/typical, then it is a good bet that...
Aug 30, 2026
Lou is in cold water. If he was down here in FL, I would say no
Aug 30, 2026
J
Jeff J
reacted to
boscoe99's post
in the thread
Are Yamaha fuel filters universal?
with
Like
For most folks it will work out if they focus on the complete model identity and year of production. They can then use the Yamaha USA...
Aug 30, 2026
B
boscoe99
Aug 30, 2026
