redneck joe
reacted to
nola mike's post
in the thread
Retirement Financial Planing
with
Like
Crazy where you can save a ton of money if you want to... I ran a few scenarios about car ownership. 1. Buying a new average priced car...
Aug 30, 2026
C
replied to the thread
Crazy happening in My area,.....
Gee, it reminds me of when the Brooklyn Bridge was built. The wire for the support cables did not meet the specs, so the supplier could...
Aug 30, 2026
reacted to
2009 stingray's post
in the thread
V/P osxi-G 5.7 lack or power and 1 beep every 5-7 seconds
with
Like
update: took the boat out with the intentions of verifying the false alert then replacing the riser sensors on the fly, verifying...
Aug 30, 2026
J
Jeff J
Ethanol!
I think this is the first time I have ever seen a claim that E10 helps keep a carb clean. My experience is exactly the opposite unless...
Aug 30, 2026
C
Rebuilding carbs
Gee, if the jets are clogged, it is not the lack of a dressing on the gaskets and orings. What shape are your fuel filters? On a...
Aug 30, 2026
Ayuh,...... AI, but watchable,....
Aug 30, 2026
T
Twert
posted the thread
88 Princecraft 16 19 pontoon manual
in
Princecraft Boats
I’ve acquired a 1988 Princecraft 16 19 pontoon boat and the capacity plate is illegible. I’m trying to find the information required so...
Aug 30, 2026
P
Pmt133
Questions about the set up of a Holley 4160 on a 4.3 V6
Lou boats where I used to boat and gets the same weather. He'll be fine. Just pump it a few extra times. :LOL: Joking aside, it was a...
Aug 30, 2026
P
Pmt133
Ethanol!
NJ makes it very difficult to get E0 or E85 for the spicy cars. :cautious: I've been all over the state and never seen E0... anywhere...
Aug 30, 2026
nola mike
Burning valves and melting spark plugs 5.7 efi
Can you monitor rail pressure on this model electronically or does a gauge need to be connected? That could tell you if the problem is...
Aug 30, 2026
B
Boaterdan278michigan
Boat purchase
I want mechanical surveyor to check compression, look over the drives, do a sea trial. A second set of eyes, so to speak. No leaks of...
Aug 30, 2026
A
airshot
reacted to
Bondo's post
in the thread
with
Like
Ayuh,..... I agree as well, but I'd start at the fuel tank, 'n inspect/ clean everything, all the way through the fuel system,.....
Aug 30, 2026
A
airshot
reacted to
kenny nunez's post
in the thread
with
Like
One other place to check. Look inside the intake manifold runners just to be sure there are no restrictions. There may be a rust or...
Aug 30, 2026
Cup420
Rebuilding carbs
Yes that definitely was a thought! Where i've been getting fuel is not a dedicated ethanol free pump. I've since found two in town that...
Aug 30, 2026
Cup420
reacted to
Jeff J's post
in the thread
Rebuilding carbs
with
Like
I’m not familiar with that product. I keep a small tub of Vaseline in the shop.
Aug 30, 2026
