dwco5051
replied to the thread
Need help! Mind of its own Johnson gt150😬
On a Johnson GT 150, the S.L.O.W. (Speed Limiting and Warning) mode activates and drops RPMs to roughly 2,500 by disabling half the...
Aug 31, 2026
dingbat
Ethanol!
Fortunately, I live in an unregulated county and I'm exempt anyhow given my AG Preservation status . Have you looked at the commercial...
Aug 31, 2026
R
Run with a timing light.----One cylinder at a time.----Will help you determine which cylinders are losing spark.----And do you have a...
Aug 31, 2026
2-4-C
must have been a dealer or marina tech. Most cummins techs just reprogram the ECM if there is an approved change from the fuel systems...
Aug 31, 2026
roscoe
stupid question - trailer lights
converts 3 light vehicles to 2 light trailer wiring ?
Aug 31, 2026
S
saltchuckmatt
Wow sounds to me like you're randomly losing a cylinder and possibly other problems. I would not keep running it and I would do a...
Aug 31, 2026
reacted to
dingbat's post
in the thread
Ethanol!
with
Like
IDK…I’ve patronized that station since built. Would have stuck out if they offered E0 as there is not really a demand around here This...
Aug 31, 2026
M
Mc Tool
reacted to
crazy charlie's post
in the thread
Are Yamaha fuel filters universal?
with
Like
Well said!! Thanks guys,I was just trying to save myself some time ordering it online since no local Yammy dealers near me. I saved the...
Aug 31, 2026
J
Jeff J
Correction: my bad experience with the parts counter happened at the Honda dealer. I let him verify my part numbers then he sold me the...
Aug 31, 2026
T
ttles714
remote motor control on-off-start
Basically the hot lead and the ground wire in the harness are the right colors but in opposite positions ,,,,, so the black ground is...
Aug 31, 2026
T
ttles714
So What I have on this harness is just what you posted ...EXCEPT !!! the black and red terminals and wires are opposite the drawing on...
Aug 31, 2026
M
mike_i
One or both
What engine are you referring to? Normally one battery should be fine.
Aug 31, 2026
M
Mark R.
posted the thread
Alpha One Gen 2 Outdrive Mystery
in
Mercury MerCruiser Sterndrives & Engines
Boat sat in storage for months last year, and then one day, gear lube just started leaking out the water inlet grate. I thought that...
Aug 31, 2026
dingbat
Aug 31, 2026
M
Mc Tool
That thing could be an interface for trailer lights . If your vehicle has led lights it wont like having high drain incandescent bulbs...
Aug 31, 2026
