M
MikeSchinlaub
replied to the thread
Boats from work.
Sep 1, 2026
Gen 4 454 harmonic balancer screaming?
Don't see a balancer making any noise because "nothing" on it will move unless it's damaged and than the ring is going to go flying off...
Sep 1, 2026
reacted to
2009 stingray's post
in the thread
2005 bravo 3 leak but no leak
with
Like
thanks for the advice guys, it was the inner prop seal, and i would not have found it if i hadn't rotated the prop shaft directly
Sep 1, 2026
Watermann
reacted to
redneck joe's post
in the thread
Random
with
Like
Sep 1, 2026
A
AceDuece
1985 Johnson 25hp J25TELCOS firing half as often on bottom cylinder at idle
I sure hope you're right on the PP. I bought a knockoff one and it was a disaster. Wouldn't plug in right, etc. Found an OEM...
Sep 1, 2026
M
Mc Tool
reacted to
jlh3rd's post
in the thread
Electric car.
with
Like
electrics have a place for some people. Free enterprise, free choices....great! "God bless america", right? And as long as Sheetz...
Sep 1, 2026
A
AceDuece
reacted to
saltchuckmatt's post
in the thread
with
Like
I run a lot of those, 100 they will run decently, 90, not so much. Might come up and like you said those compression testers all come...
Sep 1, 2026
S
supercobra
Sterndrive identification?
And what is that screw for oil for?Doesn't it get oil from inside?
Sep 1, 2026
S
supercobra
What would be a easy upgrade?
Sep 1, 2026
Anode without the fin It's an MR drive
Sep 1, 2026
S
supercobra
So what drive is this?And does that prop look to big for the anode to go there?
Sep 1, 2026
Lou C
Convert trailer for inboard use
You will have to have a new rear crossmember fabbed to make it work, otherwise to raise it enough to clear the prop safely, you will...
Sep 1, 2026
J
jlh3rd
Electric car.
Sep 1, 2026
Your missing the anode on your MR drive Surprised that big block hasn't shredded the drive yet. Merc quit putting big blocks in front...
Sep 1, 2026
R
reacted to
Jeff J's post
in the thread
Electric car.
with
Like
The problem I see with electric cars is the costs of battery replacement can easily exceed the value of the vehicle. That is why the...
Sep 1, 2026
