S
supercobra
posted the thread
Sterndrive identification?
in
Non-Repair I/O and Inboards
What model is this?Can't see the complete numbers.also on the bottom it's missing that little fin deal that bolts there because prop is...
Sep 1, 2026
J
jlh3rd
reacted to
Jeff J's post
in the thread
Electric car.
with
Like
The problem I see with electric cars is the costs of battery replacement can easily exceed the value of the vehicle. That is why the...
Sep 1, 2026
S
supercobra
posted the thread
Gen 4 454 harmonic balancer screaming?
in
Mercury MerCruiser Sterndrives & Engines
Bought this Baja force 250 with mercruiser 454 in it and replaced all gaskets .I also bought a parts engine to get parts and bolts...
Sep 1, 2026
FLATHEAD
replied to the thread
Electric car.
This one was sitting on 80% charge when I took it. Showed a range of 275 miles till a charge would be needed. That’s a fair poke, but...
Sep 1, 2026
W
Wmuncy05
Convert trailer for inboard use
Yeah I’m going to eventually get a good trailer for it, but was wanting to make this work for now while I do some work on it before next...
Sep 1, 2026
W
Wmuncy05
Yeah it seems to be fine after I got the weight off of it, but we will see once I get everything going and in the water.
Sep 1, 2026
W
Wmuncy05
Yeah ive already done that, this is just how it was when i got it from the guy that sold it to me. I was just wanting to make this...
Sep 1, 2026
J
Jeff J
Electric car.
I have made five 1,000 trips dragging a trailer in the 2 months. Probably have at least five trips remaining. That is two ten hours days...
Sep 1, 2026
Lou C
Questions about the set up of a Holley 4160 on a 4.3 V6
I tried it with the primary throttle plate set so there was .020" of transfer slot showing and the secondary open about the same amount...
Sep 1, 2026
You should only have primary idle mix screws and not 4-corner. And they should be dead nuts even
Sep 1, 2026
B
bakerjw
reacted to
newtoboat101's post
in the thread
1988 THOMPSON 240 FISHERMAN REBUILD
with
Like
agree ,it sometimes will just agree with you ,you have to specify ,what to do now or how do i do something ,if you ask it for reasuring...
Sep 1, 2026
flashback
Artificial Intelligence
I don't know how to use it. I have troubles getting my phone to work. Too many things to fiddle with.
Sep 1, 2026
flashback
reacted to
redneck joe's post
in the thread
with
Like
this is how i feel
Sep 1, 2026
C
Cconway
What parts from a ‘77 Evinrude 85 are interchangeable with a ‘73 Evinrude 115?
Could I swap the bowls and jets and use the ‘73 carbs with the ‘77 bowls if I swap the jets out?
Sep 1, 2026
2
2009 stingray
2005 bravo 3 leak but no leak
thanks for the advice guys, it was the inner prop seal, and i would not have found it if i hadn't rotated the prop shaft directly
Sep 1, 2026
