A
AceDuece
replied to the thread
1985 Johnson 25hp J25TELCOS firing half as often on bottom cylinder at idle
For sure. Fortunately I'm into the entire boat cheap enough that the outboard was essentially a freebie. Now that I have the transom...
Sep 2, 2026
A
AceDuece
reacted to
racerone's post
in the thread
with
Like
Think carefully before you spend $$$ on parts.
Sep 2, 2026
reacted to
redneck joe's post
in the thread
Random
with
Haha
Sep 2, 2026
Lowrance LCX-15 power cord
Have you tried to google it? what comes up is Lowrance PC-21X Power Cable (MPN 99-56) which is compatible with teh LCX models.
Sep 2, 2026
tpenfield
[SPLASHED] I/O (Sterndrive) Conversion to Outboards
Quick Update . . . We may get to use the boat a couple more times, but our travel plans leading into the Fall will shorten our boating...
Sep 2, 2026
T
tphoyt
reacted to
redneck joe's post
in the thread
Random
with
Like
Sep 2, 2026
redneck joe
Random
Sep 2, 2026
redneck joe
Random
Sep 2, 2026
Sterndrive identification?
Fun Times is correct. Based on the cover ... Could be a TRS drive. Then there would also be transmissions just behind the motors. A...
Sep 2, 2026
reacted to
Pmt133's post
in the thread
with
Like
You could pull the prop and measure the shaft diameter. That would at least eliminate a TR drive if you can't get most of the serial. It...
Sep 2, 2026
reacted to
Fun Times's post
in the thread
with
Like
To me I’m thinking the back cap of the upper housing suggests this drive is something different than any of the alpha type models plus...
Sep 2, 2026
reacted to
alldodge's post
in the thread
Gen 4 454 harmonic balancer screaming?
with
Like
Don't see a balancer making any noise because "nothing" on it will move unless it's damaged and than the ring is going to go flying off...
Sep 2, 2026
Cup420
reacted to
MRS's post
in the thread
Nobody fishing?
with
Like
Ha ha ha, you mean like this.
Sep 2, 2026
redneck joe
reacted to
MikeSchinlaub's post
in the thread
Boats from work.
with
Like
Sep 2, 2026
M
Mc Tool
reacted to
racerone's post
in the thread
8hp Johnson idles well, but stumbles under load, sometimes
with
Like
I doubt it is a fuel issue.----Instant improvement points to a spark issue.---Could be a broken wire.----Could be the...
Sep 2, 2026
