tpenfield
replied to the thread
Servicing my trailer bearings
I just did the brakes on my Tri-axle trailer. In doing so, I also took a look at the bearings. some are better than others. On the...
Sep 3, 2026
Texasmark
Used Glastron GX 205 with engine issues
Don't walk away from the "deal"........RUN!!!!!
Sep 3, 2026
M
Michael-Chgowiz
1986 Johnson 30hp - Vacuum lines and throttle control rod
OKie dokie. I'm not as familiar with priming system - the intake cap is the line going to the intake manifold?
Sep 3, 2026
Texasmark
Smartrail / Splash Rail for Trihull?
Can't help you there but you just caused me to recollect another of the reasons I didn't like my tri-hulls....If you were heading N for...
Sep 3, 2026
T
tphoyt
It could be an internal leak. You could try pulling the line that goes to the intake cap It and run it and see if it makes any...
Sep 3, 2026
S
supercobra
Sterndrive identification?
What is that screw for where it says oil?Do I add there or inside?I don't see a drain.
Sep 3, 2026
M
Michael-Chgowiz
Would I see the leaking after running the motor? At the moment, I don't see any sign of gas around the primer like a leak.
Sep 3, 2026
M
Michael-Chgowiz
Yes. 122 in both.
Sep 3, 2026
Many times the heat coming from the bearings is actually coming from the brakes. Might need to replace the brakes, or any of it's parts...
Sep 3, 2026
Do you want a DRY bilge?
Hope it works the way it says it does Buddy has a 40 Regal that uses packing like yours. He was going to need his re-packed then...
Sep 3, 2026
tpenfield
Boat purchase
Sep 3, 2026
B
Boaterdan278michigan
reacted to
tpenfield's post
in the thread
Boat purchase
with
Like
My guess is a 2008 Four Winns Vista 338 :D
Sep 3, 2026
reacted to
redneck joe's post
in the thread
stupid question - trailer lights
with
Like
it is a 4 slot plug, i believe the red/brown since wired together would be 'brown' of the diagram.
Sep 3, 2026
flashback
reacted to
redneck joe's post
in the thread
Random
with
Like
Sep 3, 2026
T
tphoyt
Maybe the primer it leaking a bit. They have seals that can fail.
Sep 3, 2026
