A
airshot
replied to the thread
Ethanol!
That is why the fuel you buy should be tested every so often as stations do not monitor there own fuel nor do they clean tanks and...
Sep 3, 2026
C
96 Mercury 4cyl 2 stroke oil injection
Generally speaking, the undamaged pistons and cylinders will look brand-new, and the damaged ones will look all torn up.
Sep 3, 2026
A
airshot
Ethanol!
Should have been upgraded to alcohol resistant hoses like they recomended.
Sep 3, 2026
R
Was water pump impeller replaced every 5 years?
Sep 3, 2026
eggs712
1985 Bayliner 2750 Ciera Sunbridge Resto
If I owned this place, a lot of eye sores like that would be long gone, not counting boat stuff lol.
Sep 3, 2026
Smartrail / Splash Rail for Trihull?
i was on a shake-down run on a boat with a new bulwark beach a few years bac. the water channeled past the primary door seal, in...
Sep 3, 2026
M
mike_i
Thank you for the help, boat is ready.
There's a lot of knowledge on this site and luckily a lot of guys willing to share it.
Sep 3, 2026
jimmbo
Possibly cheaper to find a used Motor, but you could end up with someone else's problem. Rebuilding yours, you would also need to find...
Sep 3, 2026
reacted to
MikeSchinlaub's post
in the thread
Repair of door latch
with
Like
Like this. Yours is small enough that you might just be able to hold it in place, or maybe screw some blocks to the middle to clamp it...
Sep 3, 2026
M
Mark R.
Alpha One Gen 2 Outdrive Mystery
Yes, I know, but that usually occurs while we are using it, or right after we use it. :-) This happened (twice now) without it being...
Sep 3, 2026
C
You realize that an oil injection failure would affect all cylinders, right? You likely have another issue, like a clogged carb, wrong...
Sep 3, 2026
redneck joe
when you get the engine is, move that gantry back over to the barn and get busy...
Sep 3, 2026
C
My neighbor had a 17" proline CC. The water would splash up along the hull like most boats, however, the bow rail would deflect the...
Sep 3, 2026
eggs712
The new motor shipped out Monday, so I made a gantry crane from two 30' sticks of 2.375" oil pipe and some scrap 2 inch round tube I...
Sep 3, 2026
Ayuh,..... As with 'bout anything mechanical, it works perfectly,... til it don't,...
Sep 3, 2026
