M
Mark R.
replied to the thread
Alpha One Gen 2 Outdrive Mystery
No. Both times, once it started leaking, it ran out in a pretty noticeable stream. I'm certain it went from no leak to significant leak...
Sep 3, 2026
P
Pmt133
Gen 2 is a little different... it should be a whole housing. I think its the whole cluser of 34-37
Sep 3, 2026
Lou C
reacted to
Sprig's post
in the thread
Used Glastron GX 205 with engine issues
with
Like
Thats not a family boat, that is a project. Walk away from that. Actually run from that. Being new to boating you do not want to start...
Sep 3, 2026
M
Mark R.
OK. I will replace them too. So items 36 and 37 in this diagram.? .
Sep 3, 2026
P
Pmt133
Is it starting leaking, or is it enough time sitting for the slow leak to finally come out of the inlet....
Sep 3, 2026
P
Pmt133
reacted to
dingbat's post
in the thread
Ethanol!
with
Like
Alcohol resistant fuel lines where mandated by the EPA in 1993 and implemented in the automotive industry in the 1994 model year...
Sep 3, 2026
M
Mark R.
Yes. Probably a good suggestion. So items 19, 20, and 21 in this diagram.? Still can't imagine what would suddenly cause them to just...
Sep 3, 2026
S
saltchuckmatt
1986 Johnson 30hp - Vacuum lines and throttle control rod
Down under humor...someone pass the salt.
Sep 3, 2026
F
fishin0001
posted the thread
96 Mercury 4cyl 2 stroke oil injection
in
Mercury & Mariner Outboards
Hi everyone need some advice, my motor got very hot and I noticed I have 125psi on 3 cylinders and 70psi on one, I did notice my motor...
Sep 3, 2026
M
MikeSchinlaub
Boats from work.
2025 Sea Doo watercraft.
Sep 3, 2026
M
MikeSchinlaub
Repair of door latch
Like this. Yours is small enough that you might just be able to hold it in place, or maybe screw some blocks to the middle to clamp it...
Sep 3, 2026
M
Michael-Chgowiz
reacted to
tphoyt's post
in the thread
with
Like
Yes
Sep 3, 2026
T
tphoyt
Yes
Sep 3, 2026
B
brodmann
Yamaha T9.9 no power to starter
Don't all Yamaha outboards have an in-line fuse that will prevent power to solenoid? Does the motor have a "dead man" lanyard?
Sep 3, 2026
Jim Hawkins
Smartrail / Splash Rail for Trihull?
I'm going to experiment with temporary test spray rails, treating each side of the hull like two separate V-hulls. I don't see any...
Sep 3, 2026
