F
fishin0001
replied to the thread
96 Mercury 4cyl 2 stroke oil injection
Ever year 👍
Sep 3, 2026
Berdink
reacted to
racerone's post
in the thread
50 looper vs 85 crossflow
with
Like
A V-4 gets best fuel economy around 3600 / 4000 RPM.----A 100 HP at 3600 RPM might run as economical as a 50 at full throttle.
Sep 3, 2026
Berdink
reacted to
saltchuckmatt's post
in the thread
with
Like
Boats are best, outboard wise, to be slightly over powered. They don't have to work as hard. Old school 2 strokes are based on the...
Sep 3, 2026
Berdink
reacted to
jimmbo's post
in the thread
with
Like
An 18ft boat, even a tinny, is not going to be much fun with a 50hp. The 85hp will certainly be a much more enjoyable drive. Top speed...
Sep 3, 2026
SHSU
1974 Chieftain 25 "Adventurer" Restoration
That is a pretty helm you are putting together. I like the real wood choice. If only I had room for such a large project/boat. SHSU
Sep 3, 2026
SHSU
1978 Islander 22 I/O
Looks good. I like your choice in vinyl!!! Admiral and I picked the same. SHSU
Sep 3, 2026
B
boscoe99
Upgraded from 2 stroke to 4 stroke Yamaha, need guages
The gauge you have does not indicate low oil pressure. Oil quantity indications only. Yes, the tachometer will tell you what the alarm...
Sep 3, 2026
C
Tilt/trim problem
Sometimes you need to "help" the motor to trim up, by grabbing it and lifting. This will bleed them as well. Just let her sit a minute...
Sep 3, 2026
M
Mc Tool
reacted to
airshot's post
in the thread
Easy way to remove carpet from aluminum deck?
with
Like
Hire a couple teenagers, they enjoy destroying stuff and can put a few bucks in their pockets...
Sep 3, 2026
C
Capt dave 258
The carpet did come up rather easily. Grabbed the corner with channel locks and pulled it up. It was soaked and dripping muddy water...
Sep 3, 2026
T
tphoyt
reacted to
redneck joe's post
in the thread
daily music fix
with
Like
Covering “Stairway to Heaven” is basically rock and roll’s third rail. Mess it up, and fans never let you forget it. Dolly Parton walked...
Sep 3, 2026
C
Capt dave 258
Tilt/trim problem
Found my release screw. See the above link. It was buried in the middle hole on the lower, port side and previous owner had it open. Too...
Sep 3, 2026
66Holiday924
This boat is my first attempt ever at doing boat interior.
Sep 3, 2026
M
Michael-Chgowiz
1986 Johnson 30hp - Vacuum lines and throttle control rod
Sorry about that, just learning. It's 1 1/2 turns out like the book said. I have two dogears - notches - and according to the Seloc and...
Sep 3, 2026
flashback
Servicing my trailer bearings
If your gonna do one then do them all. It's a messy job. One time and done.
Sep 3, 2026
