66Holiday924
replied to the thread
1978 Islander 22 I/O
The cabin window doesn't fit great. It's something I'll have to revisit later.
Sep 3, 2026
C
Capt dave 258
posted the thread
Tilt/trim problem
in
Johnson & Evinrude Outboards
Just picked up a 1992, 40hp Johnson with power trim. I had to remove the motor from the boat to get it home since I couldn't find the...
Sep 3, 2026
T
The nut
Need help! Mind of its own Johnson gt150😬
I deleted the vro and run mixed in tank And I believe the alarm works as it makes a short chirp every time I turn key on
Sep 3, 2026
garbageguy
reacted to
tphoyt's post
in the thread
Ethanol!
with
Like
This is becoming a close race with an oil thread. 😂 Makes for great reading though. Lots of info to soak up.
Sep 3, 2026
B
brodmann
Upgraded from 2 stroke to 4 stroke Yamaha, need guages
I have 1998 version digital Yamaha 6Y5 Speedometer and tachometer. When my alarm sounds, I have 4 "icons" at the bottom of the...
Sep 3, 2026
garbageguy
reacted to
redneck joe's post
in the thread
daily music fix
with
Like
Covering “Stairway to Heaven” is basically rock and roll’s third rail. Mess it up, and fans never let you forget it. Dolly Parton walked...
Sep 3, 2026
A
airshot
reacted to
Captain Caveman's post
in the thread
stupid question - trailer lights
with
Like
Well now you've learned your lesson. Never swap engines! 🙃
Sep 3, 2026
A
airshot
reacted to
redneck joe's post
in the thread
with
Like
yep found the wire and based on how it was run it was pulled during the engine swap. but, i now have lights...
Sep 3, 2026
A
airshot
Ethanol!
There are inspection officials that are supposed to inspect the fuel. Ohio is a main pass thru with the I 75 corridor and Turnpike. I...
Sep 3, 2026
B
boscoe99
Now you need to decide what sort of instrumentation that you want? Analog needle and dial. Analog with digital display. Digital with...
Sep 3, 2026
B
boscoe99
The alarm system is completely unrelated to the gauge.
Sep 3, 2026
T
tphoyt
1986 Johnson 30hp - Vacuum lines and throttle control rod
Well I it’s time to take a peek at the reeds. A some first test would be to put a pice a of paper in front of the carb while it’s...
Sep 3, 2026
S
saltchuckmatt
Your terminology sometimes gets me...so let's double check a few things. Your low idle circuit screw, how many turns out is it? When you...
Sep 3, 2026
J
Jeff J
Servicing my trailer bearings
I almost never wipe a bearing with a towel or rag. I typically clean my bearings in a can of mineral spirits, sometimes use gasoline, by...
Sep 3, 2026
J
Jeff J
reacted to
jlh3rd's post
in the thread
Electric car.
with
Like
all speculative.....biased opinion. it's a massive gamble to bet on an EV battery pack....my biased opinion.
Sep 3, 2026
