M
Michael-Chgowiz
replied to the thread
1986 Johnson 30hp - Vacuum lines and throttle control rod
Well, I held a piece of paper in front of the throat and saw no spattering at various throttle speeds. I also, on a suggestion from...
Sep 4, 2026
tpenfield
RV build quality - Rant
You have too many hobbies . . . RV's are just boats that don't float. :ROFLMAO:
Sep 4, 2026
FLATHEAD
reacted to
MikeSchinlaub's post
in the thread
Boats from work.
with
Like
No updates for a while, vacation time.
Sep 4, 2026
Mercruiser intermittent electrical / no start / no dash power
Don't know if this is day ja voo but I've seen this same post here or on another marine web site Deleting previous post to make it...
Sep 4, 2026
flashback
Boats from work.
Sep 4, 2026
jimmbo
Proper way to set points.
It helps to know what engine you are working on
Sep 4, 2026
M
MikeSchinlaub
reacted to
tphoyt's post
in the thread
Boats from work.
with
Like
Enjoy
Sep 4, 2026
M
MikeSchinlaub
reacted to
alldodge's post
in the thread
Boats from work.
with
Like
Good you could use some Vacation I'm sure
Sep 4, 2026
N
needin some help
posted the thread
in
Johnson & Evinrude Outboards
I'm back, to update i have given up on steering cable for now, being a redneck i rigged a homemade steering tiller to the engine and am...
Sep 4, 2026
B
Baba1
posted the thread
in
Mercury MerCruiser Sterndrives & Engines
2005 Searay 300DA 350 MPI MAG Engine Serial No P: OW061015 Suddenly no electric power at port helm gauges/ignition / no start on port...
Sep 4, 2026
Seems most everything is built with lower quality
Sep 4, 2026
H
Harkonnen
Successful Deletion of VST, Primer, & Fuel Pump
The thingie with the red lever, top right. Aftermarket ones tend to have the wrong inlets. Yep, I used a kit for the pump replacement -...
Sep 4, 2026
Lou C
Questions about the set up of a Holley 4160 on a 4.3 V6
Thanks!
Sep 4, 2026
posted the thread
in
Dockside Chat
I get plumbing and electrical issues..... seriously, have you ever met an Amish plumber or electrician? However lack of sealing of roof...
Sep 4, 2026
trailer spindle nut
Tighten to 20 ft-lb while spinning the hub, then back off to nearest hole
Sep 4, 2026
