R
Robobrainiac
replied to the thread
OMC 4.3 Electronic Ignition Swap
Put the boat on the water today and it is not fixed. Same issues as before. I will try to find some time for some more diag
Sep 6, 2026
A
airshot
reacted to
redneck joe's post
in the thread
stupid question - trailer lights
with
Like
well, it turns out there was a break in the ground wire. So it is an old trailer i just bought, utility. 5x10 mesh. Medium rough...
Sep 6, 2026
9
99yam40
Where to drill?
did you read what Seahorse posted in that other thread you posted a link to?
Sep 6, 2026
Alignment Tool for Aplha One Gen 2
Racing cats are shipped and trailered on their side.
Sep 6, 2026
reacted to
muc's post
in the thread
Sterndrive identification?
with
Like
It's a TRS drive, it has the smaller lower. TR drive was used on big slow boats and has a much larger prop. Inside the boat will be the...
Sep 6, 2026
N
newsailor130
Where to drill?
also, see this post https://forums.iboats.com/threads/johnson-block-venting.83954/
Sep 6, 2026
redneck joe
Random
https://www.facebook.com/share/r/1F5a9m7eKA/
Sep 6, 2026
N
newsailor130
Where to drill?
AI sort of winged it here. I am talking about 1998 type Johnson 200 Oceanrunner. A gentleman name Dhadley had offered a comment about...
Sep 6, 2026
S
SeaRayboater95
Mercruiser stalls coming out of reverse
The cable was shifting fine. I did the impeller, all the bellows, water and oil lines. I did the shift cable because I was there. I...
Sep 6, 2026
9
99yam40
Any Ideas How to Get a Stubborn lower unit screw out:1990 15Hp
Find an impact screwdriver that you hit with a hammer, they are good tools to have around
Sep 6, 2026
Cup420
Well.. got her done!
Lol...no. it was the carbs. I had to rebuild them again. One hundred percent clogged! I have no idea how it was even running.
Sep 6, 2026
Cup420
reacted to
99yam40's post
in the thread
with
Like
are you going to keep it a mystery on what you did to fix your problems?
Sep 6, 2026
M
mikebbbbb
Shift interrupt switch
I wasn't aware there is a normally closed type switch for my 3.0 mercruiser
Sep 6, 2026
M
mikebbbbb
Sep 6, 2026
M
mikebbbbb
Well, I believe mine is normally open. And when the roller pushes against the thin metal strip that activates the switch, which would...
Sep 6, 2026
