P
ptclabs.jp
replied to the thread
ad41p glow plug on while running
Thanks was able to use the diagram to solve it. Green and yellow was shorted to ground. Wish they had that book some place that did not...
Sep 7, 2026
C
15hp gamefisher wiring diagram? model 225.581508
The maxrules site has old Chrysler and Force wiring diagrams.
Sep 7, 2026
B
bakerjw
Wellcraft 210 Elite Restoration NEED HELP!!
You're doing great. As I'm late to the party, my only advice would have been to use Coosa. I missed a spot on my transom 13 years ago...
Sep 7, 2026
N
Nordin
The killswitch grounds out the CDI box. Disconnect the wire from the CDI and should have spark if there is no another issue.
Sep 7, 2026
D
damo79
reacted to
Fun Times's post
in the thread
Alignment Tool for Aplha One Gen 2
with
Like
Looks like you ought to just pull the engine and put two fresh new rear engine mounts that press into the flywheel cover as it appears...
Sep 7, 2026
redneck joe
reacted to
Elite210Captain's post
in the thread
with
Like
I had to pause on this while I finished my work office build also money was a little tight. Got the transom together with cabosil/...
Sep 6, 2026
redneck joe
reacted to
in the thread
with
Like
@Drivewayboater2 I guess your right rhe corrosion is pretty bad in multiple spots even found 2 decent size holes explains my bad fuel...
Sep 6, 2026
M
Mc Tool
8hp Johnson idles well, but stumbles under load, sometimes
There are 2 most likely possibilities , one is that there is a component that fails when it warms up , and tother is a dry joint . Dry...
Sep 6, 2026
Fun Times
Sep 6, 2026
ezbtr
reacted to
Mc Tool's post
in the thread
i'm in a fairly serious pickle...
with
Like
Yes 😁 specially with the 3 row boxes , if things get to uneven the box flexes and 🤬........😁
Sep 6, 2026
ezbtr
Just did it tonight with farm fresh eggs, go for the balance! LMAO!!!! :)
Sep 6, 2026
73 Dolphin
Lifting eye help !!
Thanks. To answer the questions. It's not a G2 motor. The 1/4 " I mentioned was roughly how far it threaded into the flywheel shaft. I'm...
Sep 6, 2026
E
Elite210Captain
Sep 6, 2026
A
ArtVandaley
Hey guys! I took the boat out today, but it was an electric only lake. However, I did poke around the engine and looked closely at the...
Sep 6, 2026
M
muc
I’ve never worked on race boats, but I have worked on wannabe race boats and they all had solid mounts or at the very least special hard...
Sep 6, 2026
