Lou C
replied to the thread
2001 Volvo Penta 5.0 GL cracked block
I have used West Marine -100 for years and when I can find it I buy Sierra PG coolant and mix it 50/50 with water. That gives freeze...
Sep 7, 2026
reacted to
Bondo's post
in the thread
with
Like
Ayuh,..... For that reason, I keep a 4" ssteel deckscrew on my intake manifold,...... It's always there when I need it, 'n I believe...
Sep 7, 2026
Sep 7, 2026
Lou C
And those PG antifreezes are ok for plastic piping but for an unyielding cast iron block you definitely want something that will stay...
Sep 7, 2026
Lou C
Questions about the set up of a Holley 4160 on a 4.3 V6
Thanks I set them to the spec I listed a few posts back for the side hung floats. If the Quadrajet runs well I think I’ll leave it for...
Sep 7, 2026
K
Kosmofreeze
Fun Fact - Water is unique when it comes to common liquids in that it expands when frozen. This is what makes blocks crack. Even if...
Sep 7, 2026
M
MikeSchinlaub
reacted to
redneck joe's post
in the thread
Random
with
Like
Sep 7, 2026
M
MikeSchinlaub
reacted to
Elite210Captain's post
in the thread
Wellcraft 210 Elite Restoration NEED HELP!!
with
Like
I had to pause on this while I finished my work office build also money was a little tight. Got the transom together with cabosil/...
Sep 7, 2026
dingbat
Ethanol!
Sep 7, 2026
dingbat
reacted to
alldodge's post
in the thread
K&N air filters......yay or nay ?
with
Like
Nay
Sep 7, 2026
Bt Doctur
Shift interrupt switch
The older switch is NLA and the newest shift plate has the updated switch and according to mercruiser the new switch does not fit the...
Sep 7, 2026
redneck joe
Random
Sep 7, 2026
ad41p glow plug on while running
What I do is bring up the page or pages I want and copy and paste into power point and save it as a jpg. I've never downloaded anything...
Sep 7, 2026
I would lower the floats a bit ..... About 7/32 to 1/4" on the primary and 5/16 to 3/8 on the secondary...
Sep 7, 2026
OMC 4.3 Electronic Ignition Swap
Are you sure your issue is ignition? Could be fuel or other What are the compression numbers?
Sep 7, 2026
