garbageguy
replied to the thread
Newbie trying to fix up a (possible) StarCraft Nova 16
cool boat! working on it with your daughter will be great! there are stickies on this subject - first thing, you have all the...
Sep 7, 2026
R
Robobrainiac
OMC 4.3 Electronic Ignition Swap
Compression has not been checked. My original issue was no spark. Even with the points being gapped. Found out thru testing it seems the...
Sep 7, 2026
redneck joe
welcome to the forum. There should be a matching serial on the block under the cowl. Verify match. Does it run? Will also want to...
Sep 7, 2026
tpenfield
2001 Volvo Penta 5.0 GL cracked block
The problem (mis-conception) with the 'pink anti-freeze via the muffs' is that a portion of the incoming anti-freeze goes directly out...
Sep 7, 2026
C
crazy charlie
posted the thread
X66 idle speed has decreased
in
Yamaha & Suzuki Outboards
2000 200hp Saltwaterseries 2 stroke sx200 . It appears that the idle speed has lowered a bit on its own. PM work that I have done in the...
Sep 7, 2026
redneck joe
iboats Football Pick 'em is back!
wednesday 720 kickoff. get your picks in.
Sep 7, 2026
C
You realize that draining the block and manifolds and refilling them with A-F is all that is sufficient to keep the block from freezing...
Sep 7, 2026
flashback
reacted to
Mc Tool's post
in the thread
i'm in a fairly serious pickle...
with
Like
Oooooh, ..... That depends on how Im going to cook them , like two if Im poaching them ,3 or 4 if Im scrambling them ....more if I have...
Sep 7, 2026
Lou C
They often crack in the cam valley inside which puts water in the oil.
Sep 7, 2026
redneck joe
2026 NFL/CFB News and Nonsense
well this is fun
Sep 7, 2026
tpenfield
I'd go with a new (replacement) engine block. If the crack is on the outside, there is probably some damage (cracks) on the inside.
Sep 7, 2026
K
kyle_r
posted the thread
in
Boat Restoration, Building, and Hull Repair
I recently purchased an "as-is" boat from an old neighbour. My oldest daughter (23) is very interested in boating and fixing one up with...
Sep 7, 2026
Lou C
Get one of those sets of small picks with the 90* tip I have dug out some old rust with it…
Sep 7, 2026
T
tphoyt
reacted to
Lou C's post
in the thread
Questions about the set up of a Holley 4160 on a 4.3 V6
with
Like
Did you mean running the auto electric choke off of a relay is unnecessary? I’m thinking so since the wire from the alternator to the...
Sep 7, 2026
Lou C
reacted to
Bondo's post
in the thread
with
Like
Ayuh,..... For that reason, I keep a 4" ssteel deckscrew on my intake manifold,...... It's always there when I need it, 'n I believe...
Sep 7, 2026
