S
saltchuckmatt
replied to the thread
1987 evinrude 140hp E140tlcua
Do a spark drop test and then do a cylinder spark GAP test. 7/16 with a bright blue crack. Spark gap tester are $12 at any auto parts store.
Sep 7, 2026
S
saltchuckmatt
Height appears correct...how heavy is the boat?
Sep 7, 2026
Lou C
Servicing my trailer bearings
Jack up the wheel on that side and spin the wheel while pumping in grease….
Sep 7, 2026
A
airshot
Newbie trying to fix up a (possible) StarCraft Nova 16
Cool looking boat !!
Sep 7, 2026
A
airshot
Sorry for the spell checker mistake....I meant NYLOK nuts, A metal nut with a nylon insert to keep it from vibrating loose.
Sep 7, 2026
A
airshot
Ethanol!
From what I have been told, each community has the option of how often inspections take place and the station' s own records are offen...
Sep 7, 2026
P
Pmt133
New Stuff on Vehicles likes/dislikes
Actually thinking about it, the export models are wired a bit different. So it may not even work. On like my truck, I can hit the...
Sep 7, 2026
P
Pmt133
reacted to
jimmbo's post
in the thread
with
Like
I don't even know how to turn the Headlights on on the Car. There is no switch on the dash, however, normal mode of Operation, is...
Sep 7, 2026
jimmbo
Sep 7, 2026
Bt Doctur
Shift interrupt switch
Shift Plate for Mercruiser Alpha, 3.0L, 4.3L, 5.0L, 5.7L Replaces 864363A1 lots on ebay at a more reasonable cost
Sep 7, 2026
M
MikeSchinlaub
Removing Spiders
You could try the Hank Hill method.
Sep 7, 2026
Lou C
OMC 4.3 Electronic Ignition Swap
https://forums.iboats.com/threads/how-to-testing-your-boats-fuel-system.278642/
Sep 7, 2026
Lou C
There is also another test that can be done that measures restrictions in the fuel delivery system using the vacuum gauge. There is a...
Sep 7, 2026
T
tphoyt
Happy Labor Day !!!
Happy Labor Day indeed. It’s the official end of the summer season here on MV and things will start to get back to some what normal...
Sep 7, 2026
P
Pmt133
You can typically force/override to full alternator output by manually turning the lights on for most GM vehicles. I'd be interested to...
Sep 7, 2026
