M
muc
reacted to
Darkhorse1201's post
in the thread
New steering cable- should it move freely in bravo 3 power actuator?
with
Like
I can push the new cable in until the head (where clevis pin goes thru) is about about an inch. After that its very tough to push but...
Sep 7, 2026
M
muc
reacted to
Bt Doctur's post
in the thread
with
Like
Did you clean the tube with a wire or brass shotgun cleaning head? The cable should go in easily with no binding thru the guide tube...
Sep 7, 2026
M
muc
replied to the thread
Alpha One Gen 2 Outdrive Mystery
You didn't post a serial number so I don't know what generation of seal carrier #17 in the pic you posted. But they have been updated a...
Sep 7, 2026
i_like_boats
85 Crestliner Nordic floor replacement
A few pics.
Sep 7, 2026
i_like_boats
Hello everyone. Well it's been some time now. got a little bit done. got the floors and what not all cut out. floors are being...
Sep 7, 2026
jimmbo
New Stuff on Vehicles likes/dislikes
looking the Owners Manual... It appear there is some control of the Headlights on the Turn Signal Switch, but an On/Off only is when the...
Sep 7, 2026
Lou C
OMC 4.3 Electronic Ignition Swap
Yes
Sep 7, 2026
A
ArtVandaley
reacted to
Mc Tool's post
in the thread
8hp Johnson idles well, but stumbles under load, sometimes
with
Like
There are 2 most likely possibilities , one is that there is a component that fails when it warms up , and tother is a dry joint . Dry...
Sep 7, 2026
R
Robobrainiac
reacted to
JustJason's post
in the thread
HOW TO: Testing your boats fuel system.
with
Like
Note, this was originally posted courtesy of Don S. Minor edits and pictures added by CaptJason A lot of you folks out there seem to be...
Sep 7, 2026
R
Robobrainiac
So you are referring to a vacuum pull from the fuel pump? Not a vacuum from the carburetor?
Sep 7, 2026
eggs712
reacted to
Lou C's post
in the thread
2001 Volvo Penta 5.0 GL cracked block
with
Like
You also have to pull off the bottom of the big hose between the 'stat housing and the front circulating pump, did you do that? GM...
Sep 7, 2026
R
Robobrainiac
reacted to
Lou C's post
in the thread
with
Like
There is a spec for how much the pump can pull at cranking speed (approx 10” Hg vacuum) and for volume I’d have to look up the exact...
Sep 7, 2026
R
Robobrainiac
reacted to
Lou C's post
in the thread
with
Like
There is also another test that can be done that measures restrictions in the fuel delivery system using the vacuum gauge. There is a...
Sep 7, 2026
R
Robobrainiac
reacted to
Lou C's post
in the thread
with
Like
https://forums.iboats.com/threads/how-to-testing-your-boats-fuel-system.278642/
Sep 7, 2026
matt167
Top left corner of the center screen is the headlight controls if no switch. The cheap eliminators work by creating an external ghost...
Sep 7, 2026
