J
Johnnyl30y
replied to the thread
200 venom idle and runability
Well that is where it gets slightly interesting. Early on in this process I was having issues so I removed the flywheel and found the...
Sep 9, 2026
rickasbury
Servicing my trailer bearings
I hear what you are saying but I feel like if I do this right and no seals are leaking, everything in the hub and bearings will be...
Sep 9, 2026
rickasbury
reacted to
airshot's post
in the thread
with
Like
Yes....if the prior grease is unkown, better to clean out everything and use a known grease to rebuild. Some types of grease do not mix...
Sep 9, 2026
B
Bman2895
Boat doesn't rise. Prop issue?
This one cant trim high enough to venitlate. Like I say it'll definitely throw a decent rooster tail trimmed up, but I never feel the...
Sep 9, 2026
B
Bman2895
I originally had the 1 3/8 carbs. Original to the 1978. And i just could not get them to act right. Very poor off-idle bogging no matter...
Sep 9, 2026
J
Jeff J
Found a destroyed raw water impeller today.. where to start looking for the pieces?
I have seen lots of those on Volvo Penta. Never really worried about it much except for the one with the cooler. The cooler seemed to...
Sep 9, 2026
J
Jeff J
Convert trailer for inboard use
The boat looks heavy on the hitch to me. It might be worth trying to slide it back a little but, as others have pointed out, you have to...
Sep 9, 2026
J
Jeff J
There appears to be quite a difference between your trailer and the ones they are trying to sell you. The rear crossmember looks closer...
Sep 9, 2026
C
Capt dave 258
Tilt/trim problem
The release valve is tight. I came across this video that may give me some insight. At about 13:43, it shows the guy working on the...
Sep 9, 2026
T
tphoyt
reacted to
JB's post
in the thread
ATTENTION - Forum Rules - ATTENTION
with
Like
Moderators will edit or delete any posts in violation of the following, and may warn, issue infractions, suspend or permanently ban any...
Sep 9, 2026
Scott06
Replaced engine now no spark
this is the sticky on TBV trouble shooting - if you arent getting 12 v on the purple wire on the positive side of the coil, you need to...
Sep 9, 2026
Lou C
OMC 4.3 Electronic Ignition Swap
set point gap, check with dwell meter, then set timing, then re-set idle speed about as simple as it gets old school tune up circa 1966...
Sep 9, 2026
aspeck
Trail Cam pix......
That is a really nice leaf! Definitely a wall hanger! Good luck finding that one in season!:ROFLMAO:
Sep 9, 2026
WIMUSKY
Trail Cam pix......
A little different, it's really windy here and it the cam caught a leaf falling out of a tree..... Finally was able to update the...
Sep 9, 2026
T
tphoyt
reacted to
Grub54891's post
in the thread
Crazy happening in My area,.....
with
Like
Interesting. I didn’t watch all the videos but, we on here know what happens when you bump the dock, sure a small ding in the gel coat...
Sep 9, 2026
