aspeck
reacted to
MikeSchinlaub's post
in the thread
Random
with
Like
12. Non-Genuine Forum Participants, such as Bots, sock-puppets, imposters, and the like will be removed from the forums as they are...
Sep 9, 2026
R
replied to the thread
1978 Mercury 70hp Worth Messing With?
In my opinion it was designed ( in a hurry ) to compete with the hot selling OMC 3 cylinder motors of that era.
Sep 9, 2026
E
eathen13
1987 evinrude 140hp E140tlcua
I beleive your correct , I’m gonna take it out Friday night and run it and will update
Sep 9, 2026
Ifishmuskie2
reacted to
Jose Almeraz's post
in the thread
1994 Mercury 115 HP RPM Read out problems
with
Like
Re: 1994 Mercury 115 HP RPM Read out problems I've been away and finally got back into town. I'm still a little confused on how to...
Sep 9, 2026
Scott06
Replaced engine now no spark
Check for 12 v at the cannon plug where the engine harness connects to the boat harness . sometimes the pins don’t make great contact...
Sep 9, 2026
Ifishmuskie2
reacted to
Bman2895's post
in the thread
Unrealistic expectations for 71 20hp johnson?
with
Like
So just an update. The motor was never quite getting full throttle. The bracket responsible for holding the throttle linkages and by...
Sep 9, 2026
Ifishmuskie2
reacted to
Capt dave 258's post
in the thread
Tilt/trim problem
with
Like
Just picked up a 1992, 40hp Johnson with power trim. I had to remove the motor from the boat to get it home since I couldn't find the...
Sep 9, 2026
Ifishmuskie2
reacted to
alldodge's post
in the thread
Servicing my trailer bearings
with
Like
For the most part yes, than take your finger and dig out all the grease around the castle nut and put the seal back on. Your digging...
Sep 9, 2026
Ifishmuskie2
reacted to
Jeff J's post
in the thread
with
Like
Personally, I would not fill the hub if there is no zerk fitting. I don’t use the zerk fitting even if there is one. I do spread some...
Sep 9, 2026
Ifishmuskie2
reacted to
rickasbury's post
in the thread
with
Like
When you say pushes it to the front bearing, that is pushing through the rear bearing ,existing and then travels through the hub and...
Sep 9, 2026
Ifishmuskie2
reacted to
tpenfield's post
in the thread
with
Like
It takes the grease to the rear bearing and then the grease pushes to the front bearing. with that you can see what the existing grease...
Sep 9, 2026
J
jlh3rd
well, I have a karavan trailer with the sure-lube system. I can't be sure that if I change a grease base that using that system only...
Sep 9, 2026
FLATHEAD
reacted to
WIMUSKY's post
in the thread
Trail Cam pix......
with
Like
A little different, it's really windy here and it the cam caught a leaf falling out of a tree..... Finally was able to update the...
Sep 9, 2026
T
tphoyt
reacted to
flashback's post
in the thread
How do i get this out?
with
Like
Wet sand it with 800- 1000 grit sandpaper and then buff with a good buffing compound.
Sep 9, 2026
T
tphoyt
reacted to
in the thread
Random
with
Like
Sep 9, 2026
