M
Mc Tool
replied to the thread
1978 Mercury 70hp Worth Messing With?
the design of the plenum could have a bearing on the 120 deg intake pulses , being that one carb would be drawn on evenly its the...
Sep 10, 2026
jimmbo
1987 evinrude 140hp E140tlcua
With a 4 inch drop in Pitch, it still won't go above 3000rpm. Even with a dead cylinder the revs would go up, with less pitch. I would...
Sep 9, 2026
jimmbo
The problem with the 2 carbs for 3 cylinders is that a 3 cylinder has 120 degrees between inhalations in the induction systems. With...
Sep 9, 2026
M
Mc Tool
Thanks jimmbo . Guess it what one is used to seeing , all the motorbikes I recall had one carb per pot , and then I saw some 2 strokes...
Sep 9, 2026
R
Robobrainiac
reacted to
Lou C's post
in the thread
OMC 4.3 Electronic Ignition Swap
with
Like
set point gap, check with dwell meter, then set timing, then re-set idle speed about as simple as it gets old school tune up circa 1966...
Sep 9, 2026
McGR
Have a 76 Johnson 85v4 will a 85 power trim& tilt fit
The original factory t/t units for that vintage of OMC V4 are pretty hard to come by. While it was an available option, most V4 motors...
Sep 9, 2026
jimmbo
It was that way because of the Design of the Reeds, Mercury had on their Production Inlines. In 76, merc did make a 650XS which had the...
Sep 9, 2026
jimmbo
Boat doesn't rise. Prop issue?
The 78 140 heads aren't too bad for compression, the tightest heads were on the 1973 135hp, but they are borderline on today's...
Sep 9, 2026
M
MikeSchinlaub
reacted to
aspeck's post
in the thread
Random
with
Like
Wow! Someone actually read the rules! And it was a sock-puppet! Go figure! Now we have an enigma wrapped in a dilemma … we can’t ban...
Sep 9, 2026
aspeck
reacted to
flashback's post
in the thread
Random
with
Like
Gonna have to moderate the moderator.
Sep 9, 2026
M
Mc Tool
Random
Ha ha I bet Joe has to " substantiate his identity " after posting that avatar then 😂😂
Sep 9, 2026
M
Mc Tool
Yeah ,Im thinkin the 2 carbs for 3 cylinders is a bit of a patch job using what was laying around at the time ....and probly same thing...
Sep 9, 2026
flashback
reacted to
aspeck's post
in the thread
Random
with
Like
Sep 9, 2026
flashback
Random
Sep 9, 2026
aspeck
Random
Sep 9, 2026
