B
boscoe99
replied to the thread
No tach,no charging
This is from a Mercury service manual for the OP's voltage regulator. But even if the regulator tests well, with no DC output with...
Sep 12, 2026
B
boscoe99
No tach,no charging
You are seeing battery voltage on the stator output wires with those wires not connected to the regulator?
Sep 12, 2026
B
boscoe99
No tach,no charging
It is a voltage regulator. Not just a rectifier.
Sep 12, 2026
Sprig
reacted to
tphoyt's post
in the thread
Big Thanks
with
Like
I just want to give a Big Thanks to all the mods. You’re all rock stars for donating your time to running this great forum. Thanks to all
Sep 12, 2026
Ifishmuskie2
reacted to
99yam40's post
in the thread
No tach,no charging
with
Like
like Boscoe99 said the yellow wires need to be disconnected from the RR when testing for AC to see if it is putting any AC voltage
Sep 12, 2026
Ifishmuskie2
No tach,no charging
With engine turned off I get battery voltage at the two yellow wires from the stator at the junction box near the coils.
Sep 12, 2026
Maybe my turn for new boat time
No, mine with cash from me Boat didn't have a trailer, so I pay them 49K
Sep 12, 2026
9
99yam40
No tach,no charging
Sep 12, 2026
C
No tach,no charging
That is normal behavior for the tach.
Sep 12, 2026
C
Checking the Wiring of the Assist Solenoid
The slave solenoid battery post is often used as a junction for all wires carrying a continuous +12VDC power. So if you have any wires...
Sep 12, 2026
Ifishmuskie2
No tach,no charging
When I turn the key the tach moves to zero and the volt gauge moves the 12.5volts
Sep 12, 2026
Berdink
reacted to
Mc Tool's post
in the thread
1978 Mercury 70hp Worth Messing With?
with
Like
yep . One of the things that makes a good mechanic ( or any repair man ) is the ability to diagnose the problem and one advantage a...
Sep 12, 2026
C
No tach,no charging
There is no bench test for a voltage regulator that I know of. You could feed it 16VAC and see what it puts out. It should try to put...
Sep 12, 2026
tpenfield
Yes, I was going to offer some guidance and technical assistance on that. :LOL: Probably twin 250 HP
Sep 12, 2026
tpenfield
So, is the dealer taking your boat (Chap 280) and trading it for the Formula 270. . . . Like an even swap?
Sep 12, 2026
