P
Pmt133
replied to the thread
[SPLASHED] I/O (Sterndrive) Conversion to Outboards
I get that from the RC cars. :p
Sep 12, 2026
redneck joe
Maybe my turn for new boat time
ok good that makes more sense...
Sep 12, 2026
Ifishmuskie2
reacted to
Mc Tool's post
in the thread
No tach,no charging
with
Like
yeah , the stator is under the flywheel so you would have to remove that ... and that can be a mission , even getting the nut undone...
Sep 12, 2026
S
SeaRayboater95
Milky oil
Is there and order to check these different possibilities? Is it visual, or do I need to pressure test? I remember from years ago that...
Sep 12, 2026
nola mike
Nope.
Sep 12, 2026
nola mike
Milky oil
Yeah, my remote filter from Summit is also Ford style.
Sep 12, 2026
M
Mc Tool
No tach,no charging
Sep 12, 2026
reacted to
alldodge's post
in the thread
Air Trapped in Outdrive...
with
Like
Yes there is some air and how much depends on how the drive was refilled. On the boat, off the boat and angle. It also takes a little...
Sep 12, 2026
C
canadianboater86
Have a 76 Johnson 85v4 will a 85 power trim& tilt fit
Yes i’m in ontario canada
Sep 12, 2026
redneck joe
Cats as in converters i assume?
Sep 12, 2026
redneck joe
reacted to
alldodge's post
in the thread
with
Like
Depends on fresh or salt water, I'm in fresh so don't worry much about corrosion. Impeller is cheap enough, everything else is not like...
Sep 12, 2026
redneck joe
i look at my to see where the fuel line is on the tank. Pretty accurate.
Sep 12, 2026
D
Derrick b
reacted to
soundguy's post
in the thread
Batteries in series and parallel
with
Like
Re: Batteries in series and parallel Thanks for the info. Currently the batteries are not in parallel. The outlet (as pictured above)...
Sep 12, 2026
H
highpowerdad
posted the thread
Transom to Trim cylinder hose leak
in
Volvo Penta I/O & Inboard Gas Engines & Outdrives
HI all, SX-M drive setup, so, I have a slow leak in one of the hoses that go from the transom to the Trim Cylinder, Port side if it...
Sep 12, 2026
rickasbury
Servicing my trailer bearings
So, interesting day.It's 500 degrees here in fl, no shade...on asphalt 1st- the boat has barley moved for the last six years...couple...
Sep 12, 2026
